damonposey
- Nov 1, 2006
what the frickity frack, this is wackity wack..(I'm hip to our youths' lingo!) I want to set the chipset voltage but I just am not sure which one it is. This is a gigabyte ep45-ud3r. The manual doesn't help either. Any ideas?
Maybe you might change something differetly in this situation though. I'm at 4.0ghz with an e8400 and im at 1.28 volts. memory stable, temps great. Prime gives an error after about 6 hours. Should I up the vcore higher before touching chipset voltage?
