okay player
- May 24, 2012
Hi guys,
I recently bought a new external HD and thought I'd try to get the most of it by adding USB 3.0 to my PC.
The hardware and driver install seems to go fine, but shortly after that I get a pop-up claiming:
"Power Surge on Hub Port
A USB device has exceeded the power limits of its hub port."
which seems odd considering there isn't anything connected to it.
I've tried uninstalling and completely removing the device as well as installing a completely different USB 3.0 PCI Express card with the same results. Also tried resetting BIOS to factory default and that didn't help either. Is this an issue with my mobo?
Any idea's?
Thanks!
Any idea's?
Thanks!
