Cant get my Asus K8N-E running !
~ever~
Well I got this Mobo after trying to install an Athlon 64 DTR 3400 on an Abit NF8 and having no success. Today I got this Asus Mobo and It Posts and everything BUT right before it goes into Windows, I get a Blue Nasty screen telling me tat if its the first time to restart and all that crap. I dont have any clue as of why this is happening. Can anyone help me ? The Mobo is brand new and its making me mad :mad:
BTW, I tried powering the rig with just my RAID setup of Raptors and nothing else, i.e. , My Plextor 716SA, an same.I tried just one memory stick and nothing, Same thing..........
Please Help!!!
Did you reinstall Windows after you switched MoBo's? You didn't say, but I've seen that screen or a boot loop when there is a problem with old drivers and new hardware? I'd also try Memtest86 to see if your memory is the problem.
No, I did not reinstalled Windows XP. I have way tooo much stuff to just format it, And it would take me forever to back them up on CDs, I bought a Pleaxtor 716 but its SATA so I cant use it on my old setup, it doesnt have enough SATA ports......
Do I have any other options ?????
I'm surprised it recognized your RAID array after switching MB's. If I were you, I'd throw all your old stuff back on your old MB (didn't say what it was), and then backup everything you need. When you switch MB's like that with different RAID controllers it's not going to keep your RAID array intact (at least not usually). You might want to get a cheap IDE HD to back stuff up on to. You can get a 120 GB one for like $40 after rebates if you look around.
So its a Problem with my RAID setup ?????
I asked around and noone seems to see a problem with that....
Anyone with this Motherboard and a SATA RAID setup having problems ???
Please help, I need to see if this can be fixed or I need to change the motherboard before my local store doesnt take it back....
I had the same problem when I tried to hook-up a HD with a new mobo. Common sense and a bit of thought makes it easy to see why it wouldnt work. You need to reinstall your OS on anotherdriver or whatever and install the drivers that should be on a disk that came with your mobo.
Go into BIOS and change your boot order. Make your Optical (CD) the first and reinstall the OS then immediatley instal the drivers for your new mobo.
As a side note, you should have prepared by backing-up your data before switching mobos, in preperation for a nice clean install.
No it's not a RAID problem only, it's a Win XP problem.
If you change your hardware, mainly motherboard, to something that differ to much from what you had before, Win XP will regard this as a new system and needs to be re-installed.
Sadly there's no way around it. If you still have your old things and they work, put them togather again and do a backup of all important stuff.
JL had the right idea. You can perform a restore on the machine. Boot from your XP cd, hit F6 to install drivers for the chipset. I cant remember all of the details exactly, but it'll just re-install the driver portion of the registry and will NOT format or mess your system up. Word of caution though.. Ive done this many times with family computers or business machines, and it is not always stable. I mainly do this to get to the data to back it up then end up formating. You might get lucky though.
Well this seems logical, I mean, After all im getting a whole new platform, But the thing is that I have Windows XP Pro Corporate, And I didnt think these kind of features were active on this version... If you know what I mean....
