Cant get a any screen input
giser3546
I have been without a proper desktop for quite a while but Recently I was given a new (to me) Gigabyte GA-990FXA-UD3 (rev. 3.0) mother board. I added a PNY Geforce GT 610 1 gb graphics card and two 1 gig sticks of Kingston KVR1066D3N7K2/2G DDR3 just to get the thing booted but can't get the monitor to even detect any input.
I have tried all of the different outputs on the graphics card on two different monitors and even tried a different graphics card with no change. I did look up the compatible memory for this particular motherboard and while it does include KVR1066D3N7/2G it does not include KVR1066D3N7K2/2G. Is that my problem?
What are your power supply specs? it may not be providing enough power to the video card..
or you have a dead video card.. the type of memory has nothing to do with the video not working..
Try the card in another pc and see if it works.
you tried another video card and it didn't work either? that narrows it down to the power supply or motherboard, try installing the videocard in a different slot?
IF that dosent work then i suspect you got a faulty board or power supply. i'm betting on it being the power supply.
reset the bios on the motherboard, try that
1. remove card and open BIOS
set Graphics to PEG
set Internal to disabled
min memory stick size is 1GB (single side populated). if you are using double sided sticks you are SOL if they are low density chips
KET23B1 Kingston 1GB KHX2333C9D3T1K3/3GX SS
SET20B1 STAREX 1GB STH100UD0814-2000A SS
TA20B1 Team 1GB TXD32048M2000HC9 SS
KET20B1 Kingston 1GB KHX2000C9AD3T1K3/3GX SS
KET186B1 Kingston 1GB KHX1866C9D3T1K3/3GX SS
W16B1 Winchip 1GB GDF1GB18L150C9 SS
CR13B1 Crucial 1GB CT12864BA1339.8FF SS
GSET186C1 G.SKILL 1GB F3-15000CL9D-4GBRH DS
O13B1 OCZ 1GB OCZ3P13332GK DS
The motherboard has no video outputs, they are only on the graphics card.
