Can't figure out this freezing...
SeaFoam
So my brother tells me his system is locking up a lot, dropped off the box. That's all I know.
So far I have ran LinX w/ 100% mem usage, FurMark and Memtest and haven't gotten a freeze or an error.
Any ideas? I'm going to run these some more but I'm at a loss at the moment.
He just told me that the biggest problem with freezing is with youtube, which makes me lean toward the video card.
Can't duplicate?
Ask him what he's doing to freeze it. Also try a chkdisk, I recently had bad HD sectors cause my computer to lock up on me.
EDIT: Didn't see your 2nd post...
Seems like a software issue if it's passing Furmark just fine... Try updating video card drivers?
was on latest drivers, letting it run youtube videos
Start backing up data now.
Additional tests:
[Testing the Hard Drive]
Download the CD image of Hitachi Drive Fitness Test, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Test the hard drive and see if any problems are found. DFT will run on most manufacturers' hard drives. Alternatively, you can use Seagate's SeaTools for DOS to test a Seagate or Maxtor drive. For a Western Digital drive, you could use Data Lifeguard Tools for DOS to test a Western Digital drive.
passed DFT and chkdsk, guess i was premature on the chkdsk - nothing really in event viewer. i suppose the board could be bad again..
Reseat all connections inside the case. RAM, ATX Connector, HDD.
Heatcreep can affect memory and other components in this funky fashion.
What are the specs of the PC?
Also did you reseat all the connections as some have recommended?
And what were the results of you watching youtube on that PC? Did you try different browsers?
Are these intermittent crashes?
