The "j1"? I don't understand what you mean here.keyser said:do iput the bridge in wrong? the j1 goes on the top card right?
sheeshkeyser said:and yes i tried both cards in single mode
Let us know if you ever get it working.keyser said:thanks a lot guys.
I have a few of mine posted here if you would like to see them.Warrior said:having that all said..can you post pictures of you setup?... the sexy SLI gets me everytime
I think one should always used stock settings, final BIOSes, and official drivers intially. That is why I recommend that one first install the official 66.93s from nVidia's site and only try other driver revisions after it works with these.kirbyrj said:Don't know if you got it working or not, but I think it's a driver issue. I tried the beta drivers from Nvidia.com, and got stuck in a boot loop/BSOD with 6600GT's. Then I downloaded the 71.81 drivers that I saw on this forum, booted into safe mode, driver cleaner, installed the new drivers and SLI worked great ever since.
http://www.hardforum.com/showthread.php?t=868384&highlight=71.81
ohnnyj said:I think one should always used stock settings, final BIOSes, and official drivers intially. That is why I recommend that one first install the official 66.93s from nVidia's site and only try other driver revisions after it works with these.
It doesn't matter if they are WHQL certified, they may not have SLI functionality. I know that some drivers out there will not allow SLI to work, hence this could be your entire problem right there. At least with the officials I am absolutely certain that SLI is supported as they are the very drivers I am running right now.kirbyrj said:While not an official driver, they are WHQL certified if you're into that kind of thing. Like I said, they worked great for me, although I never did try the 66.93's with SLI.
