Sir_Poop_Alot
- Aug 2, 2008
I got 12GB (3x4GB) kit of Corsair Vengeance ddr31600 in my hands. I am torn between selecting the i7 950 and the i7 2600K. I am replacing the cpu/mobo/ram items in my current system (see sig.) Microcenter is 5 minutes from my work and I can pick up an i7 950 for $199 or the i7 2600K for $279.99. So guys what should i do? Go with the 2nd generation and pay the 2nd generation price or stick with the 1st generation. The difference between the two after much research is that the 2600K is 32nm vs 45nm (i7 950) and it can overclock higher, runs cooler and draw less power. Below are some additional questions/info:
1.) Is there a difference in performance between tri-channel vs. dual channel?
2.) I will be using the new build for the following:
+ software development (c/c++/c#/java)
+ cs4 and upgrading to cs5
+ video encoding
+ occasional gaming (FPS)
+ VMs
3.) Are the mobo for the i7-2600K stable enough since right now is the initial release
4.) If i go with i7-2600K probably get another 4GB stick so use up all the slot (4x slots).
So what do you guys think? TIA.
+ video encoding
+ VMs
