Cant configure
Billybob51106
Vista ultimate 64, Q6600, 8 gig.
Downloaded latest install, replaced with *.exe with the latest beta. Ran cmd - install and followed steps...
Soon as the size comes up, if I hit enter or type big, it crashes.
UAC is turned off btw, any hints.
-Bill
I know that problem and it's really irritating. Your only way is to configure this on another computer then move the client.cfg file to your Q6600. I don't know of a way to complete the config to the end if it crash in the middle.
Think I got it figured out...
After the crash, I ran fah.exe and downloaded work, then shut it down and deleted the work folder, reran -configonly and this time it took :/ back to seeing if it works right this time
-Bill
