ir0n_ma1den
- Oct 30, 2007
I bought a new router about a month ago (DIR-615) and it was working fine till about 2 weeks ago. My computer, my dads computer, and my brothers computer are wireless while my moms computer is wired. The only wireless computer that can connect to our network is my dads computer. Me and my brother have to use a random network. We all use the Network Magic program that came with the router.
Our network is WPA-PSK TKIP secured (done by me
). I try to find our network by typing in the SSID and the password, but I still have no luck.
Through the router firmware, my computer and my Dad's computer are on the DCHP reservation list, but my Dads computer is the only one that can see the network.
I have called D-link, and Netgear about this and they have guided me to using the windows network manager, but I still have no luck.
So the problem is that I cannot connect to my network at all. It doesn't even show up when I try to find a network. Distance is definitely not a problem as I was getting signal when we first got it, and I also have a range booster.
I have faith in the [H] community, help me!
if you need screenshots i'll be glad to give them to you.
Thanks
Thanks
