Can you explain what's wrong with my PC?
icor1031
I already know how to solve my problem, but I'm posting because I don't understand why it solves anything.
For quite a while, my PC has been turning itself on immediately after I put it to sleep -- even if I'm not touching it. After putting it to sleep multiple times, sometimes it would stay asleep -- until I touched some component, e.g. my metal mouse pad (which my mouse was on top of).
When I used the switch at the back and set my PC to off, it did of course go off. But if I set it to on, my computer would turn itself on, even without pressing the power button.
Lately, my PC has been locking up. Even task manager would crash.
Today, it finally died. I turned it on, went into bios, and my screen flashed a bunch of times. Then the video signal almost entirely locked up. I pressed a bunch of buttons, and it updated one time and was distorted. Then it went blank entirely.
From that point forward, I had no video signal. It didn't matter whether I used onboard on my GPU. Despite this, it did seem that my PC was loading into windows, though I can't be sure of that.
I swapped RAM, RAM slots, removed my GPU, removed storage devices, and nothing helped. It still gave me a blank screen when I tried to turn it on. Sometimes I'd get a screen for a short time before it went blank, but usually not.
... Then I switched from my onboard-driven DVI monitor to my DP monitor. Since then, I haven't had a problem. I've even put all of my RAM and my GPU, etc. back into my PC.
I went back to onboard DVI a couple of times, and I had problems right away.
Also, the weirdness with my PC turning itself on without my permission, and having it visibly discharge when I press the power button when the power switch is off (I didn't mention this previously), those problems are solved too.
And I am now using that same DVI, but with my external GPU. If I plug it into my onboard, I'll have problems.
My onboard drives DP without any problems. It's only when it tries to drive DVI that it has any problems.
What caused this? I am extremely curious. A short related to the DVI port? A defect within my CPU that's activated only when that port is being used?
icor1031
Update: It just crashed again. Whatever is wrong, it seems that using onboard DVI just exacerbates it severely. I'll be testing my RAM soon.
owcraftsman
#1 don't blame MSI for a windows bug. Sleep/Resume is wholly a windows power options issue.
The only resolve is to format and reload windows and pray it works after.
I personally avoid Sleep for this very reason and I've had issues with it on Gigabyte Asus and MSI boards since Windows XP.
#2 In lieu of a format and reload check what power buttons do from the power options appellate.
Open power options:
  • Windows 10, select Start , then select Settings > System > Power & sleep > Additional power settings.
  • Make sure under "select what power buttons do" power button (only) is selected for Sleep which subsequently functions to resume as well. There is an option to wake from keyboard and mouse, which I suspect may be your issue, so you want to make sure that is not selected from the drop down.
icor1031
Open power options:
But as I said, my PC turned itself on even from having been fully off -- so it's not just a sleep issue.
It also woke upon contact with my mousepad (static electricity).
If you have static electricity issues I highly suggest using gloves or the ground strap when touching internal components. Check the CPU socket for bent pins. Otherwise the board may be damaged.
icor1031
Yes sir, I always use a strap, regardless of conditions.
Wooshoo
Ugh I should get and use a strap. As an electrical engineer and computer enthusiast/hobbiest for the past 10yrs I really shouldn’t be so lazy. And now that my computer is actually worth a damn even more so.
Denpepe
That reminds me of this video
FrgMstr
Just Plain Mean
Staff member
Always keep a PSU close by, plugged in, so you can easily discharge yourself while working. Much easier than a strap catching on stuff and knocking stuff off your work area all the time.
cmalcolm48
Heres a question what power supply do you have in the computer? A bad power supply can cause all sorts of problems.
TheSlySyl
Not sure if this has been resolved, but for me when this issue happens, 99% of the time it's because I have a console controller attached.
I think its because the triggers are so sensitive that they register as being pressed, but usually I just unplug the controller and it sleeps all night with no issues.
