Lazn_Work said:http://www.anandtech.com/mb/showdoc.aspx?i=2580&p=10
As far as I can see, only in the first two graphs on that page.
edit:
"We benchmarked F.E.A.R. with the newly released NVIDIA 81.85 WHQL driver set, based upon recommendations from NVIDIA about further optimizations for SLI-AA and Dual Core processors that would show marked improvements for the x16 product at higher resolutions over the x8 product line. The Asus P5N32-SLI Deluxe indicated an almost 3% gain over the MSI P4N Diamond in the previous 1280x960 benchmark. As the resolutions increased in the standard AT benchmark settings, the ability of the MSI P4N Diamond with its x8 SLI configuration fell behind the Asus P5N32-SLI Deluxe by upwards of 11% in this application. Once we changed the standard benchmark settings to include 2x AA and 16X AF, the benchmarks ended up favoring the Asus P5N32-SLI Deluxe by 25%. Based upon these results, we can conclude that the additional 8GB/second of bandwidth afforded by the additional 16 PCI Express lanes and the 81.85 driver optimizations allow a great deal of headroom potential at the higher resolutions with today's hardware. "
==>Lazn
Because it's relatively safe to assume that the bus bandwidth increase would have similar effects across platforms, especially given that NVIDIA build the chipset "platform" for both.J-Mag said:I still don't understand why you guys are comparing these results to the AMD platform. I mean christ, do you bench on an Intel rig that is let's say OC'd 200mhz and then conclude you would get the same results if you OC'd an AMD rig 200mhz?
Hurin said:So, smarty pants, do you expect AGP 8X and AGP 4x to behave differently across AMD and Intel platforms?
J-Mag said:If you take an Intel SLI board and an AMD SLI board and then compare the differences between Single GPU performance and SLI performance you will notice a greater improvement on the AMD platform than on the Intel platform. Therefore, there might be a NEED for the intel side to have more bandwidth.
Anyway AGP is a standardized spec across platforms. Is SLI?
Hurin said:Because it's relatively safe to assume that the bus bandwidth increase would have similar effects across platforms, especially given that NVIDIA build the chipset "platform" for both.
SirFragalot has already addressed most of what youv'e said (thanks!). You should also be made aware that you aren't even asking the right question here. AGP is a bus standard just like PCI-E. SLI is a technology for running two video cards. By equating SLI and AGP, you're comparing apples and oranges. The proper question (which you wouldn't ask because it's obvious) is: "AGP is a standardized spec across platforms. Is PCI-E?"J-Mag said:Anyway AGP is a standardized spec across platforms. Is SLI?
Sir-Fragalot said:No. There is a greater improvement because the AMD platform is better at games. All SLi benchmarks will naturally be better on the AMD processors as a result of their superior gaming performance. Not because they have different bandwidth needs when it comes to video cards. This notion is absurd as PCI-E is PCI-E. Both platforms impliment it the same way. The reason for the difference in chipsets is due to AMD having an integrated memory contoller into the CPU, and Intel doesn't.
Sir-Fragalot said:Intel and AMD based rigs are very hard to compare for something like this as the technology behind them is like night and day.
The drastic performance increase we are discussing here manifests itself only when SLI-AA is used. Not just AA. Not AA on an SLI system. But a discreet AA rendering mode called "SLI-AA" that must be specifically enabled and selected. This mode shares the AA duties between the cards. When that is selected, as hothardware reports, there is a dramatic jump in performance between the Asus motherboard using 8x PCI-E and the Asus motherboard using 16x PCI-E.J-Mag said:Then why does the Anand Article show an "Once we changed the standard benchmark settings to include 2x AA and 16X AF, the benchmarks ended up favoring the Asus P5N32-SLI Deluxe by 25%. "
Then the Hothardware article on the AMD platform you don't see improvement at all? (yes they are tesing different games, but at least they tried 4xAA on Farcry)
Hurin said:SirFragalot has already addressed most of what youv'e said (thanks!). You should also be made aware that you aren't even asking the right question here. AGP is a bus standard just like PCI-E. SLI is a technology for running two video cards. By equating SLI and AGP, you're comparing apples and oranges. The proper question (which you wouldn't ask because it's obvious) is: "AGP is a standardized spec across platforms. Is PCI-E?"
Hurin said:That answer: Of course it is. Which is why guaging an increase between 8X PCI-E performance and 16X PCI-E performance on an Intel platform is useful in determining the validity of hothardware's report of a dramatic performance increase between 8X PCI-E vs 16X PCI-E SLI-AA on AMD platforms.
I believe that you are fundamentally misunderstanding the point of this thread as I posted above (I responded to your post to SirFragalot while you were writing this). See above.J-Mag said:I am not worried about the bus performance. I am worried about SLI performance. . .
Either way we cannot disprove each other unless another review comes out and uses FEAR with a 32x PCI-E AMD motherboard. I will bet you anything that you wont see a 25% increase like you did on the Intel side.
Hurin said:The drastic performance increase we are discussing here manifests itself only when SLI-AA is used. Not just AA. Not AA on an SLI system. But a discreet AA rendering mode called "SLI-AA" that must be specifically enabled and selected. This mode shares the AA duties between the cards. When that is selected, as hothardware reports, there is a dramatic jump in performance between the Asus motherboard using 8x PCI-E and the Asus motherboard using 16x PCI-E.
Hurin said:Now, if you have an Intel system with 8x PCI-E and another Intel system with 16x PCI-E, and a similar jump is reported, that is good information that can be used to confirm what hothardware reported. It is not silly or stupid to compare Intel and AMD platforms in this instance because the components in question are really just the video cards and the PCI-E bus. And a jump on both systems would be indicative.
Hurin said:Sadly, Anandtech didn't really seem to test SLI-AA in a way that would be helpful in confirming hothardware's findings. But, had they tested an Intel system in that manner, it would indeed have been useful.
Clear enough for YOU?Hurin said:Clear enough for you?
Hurin said:I believe that you are fundamentally misunderstanding the point of this thread as I posted above (I responded to your post to SirFragalot while you were writing this). See above.
I suggest you go back and look at your first post in this thread and reconsider who is being "condescending" here.I know what SLI AA is, you don't have to be condescending...
I'm not sure how you can say this when you then go on to agree with me that Anandtech did not properly test for an increase in SLI-AA performance on the Intel system.And yes I agree there is only a performance increase on the AMD platform in SLI AA modes.
But, again, as you concede, Anandtech did not test properly to verify or discredit hothardware's findings. Are you saying that, had Anandtech actually tested 8x SLI-AA and 16x SLI-AA between the 8x PCI-E and 16x PCI-E platforms, that those results would have been "silly" or "meaningless" in determining if hothardware goofed or not?It is silly to compare because there are totally different results showing at standard AA modes. INTEL gets an increase (according to Anand) and AMD doesn't (according to Hot).
Might I therefore respectfully suggest that you contribute to another thread more in-line with your goals? The results that you malign from an Intel board would go a long way in satisfying the question raised by the original poster and the purpose of this thread . Up to this point, your posts have amounted to little more than subtle thread-crapping and/or an attempt to hijack the topic and redirect it away from its intended topic (whether the SLI-AA performance improvement is real).OK well maybe it is useful to some people, but not me
You do now. I don't think you did when you first crapped on it and belittled those taking part in it.J-Mag said:I realize what the point of this thread is. . .
Matrices said:Doesn't anyone remember the first fiasco with people unlocking non-SLI boards into SLI capability with a pencil or something? So with one PCI-E 16x and one PCI-E 1X, you could get 95% of the performance of whatever the "real" SLI board was...shouldn't that tell us something?
Hurin said:I'm not sure how you can say this when you then go on to agree with me that Anandtech did not properly test for an increase in SLI-AA performance on the Intel system.
Hurin said:Are you saying that, had Anandtech actually tested 8x SLI-AA and 16x SLI-AA between the 8x PCI-E and 16x PCI-E platforms, that those results would have been "silly" or "meaningless" in determining if hothardware goofed or not?
Hurin said:Your sole contribution to this thread is to claim that we are somehow silly or lame for looking at results from an Intel system while trying to determine whether hothardware's
findings are valid where an increase in SLI-AA performance is concerned.
Hurin said:Might I therefore respectfully suggest that you contribute to another thread more in-line with your goals? The results that you malign from an Intel board would go a long way in satisfying the question raised by the original poster and the purpose of this thread . Up to this point, your posts have amounted to little more than subtle thread-crapping and/or an attempt to hijack the topic and redirect it away from its intended topic (whether the SLI-AA performance improvement is real).
Matrices said:I don't believe this stands up to scrutiny:
"No. There is a greater improvement because the AMD platform is better at games. All SLi benchmarks will naturally be better on the AMD processors as a result of their superior gaming performance."
It's utterly irrelevant what processor you are running when you are talking about real-world gaming performance between a P4 2.8+ and an AMD643000+ at 16x12 4xAA. That is entirely GPU-bound. We're not talking about running Q3 at 8x6 and that is meaningless.
The bottom line here is the Anandtech article shows 25% performance increase on 16xPCI-E versus PCI-E in SLI, in FEAR, at 16x12, 2x REGULAR AA, on an Intel board, compared to another Intel board.
What is so hard to understand about this? Unless you can claim that for some reason such results cannot be reproduced in an AMD situation involving 8x PCI-E vs. 16x PCI-E, there is no basis for dispute.
Uh, okay. . . you first came here and pointed out how ridiculous you thought looking at an Intel board was. So, no, you didn't say it was "silly" you merely attempted to convey how ridiculous you thought we were for analyzing Intel board performance. Then, oddly, you admitted that analyzing Intel results would be useful. Now you're back to calling doing so silly. So, really, I don't know what to do with you at this point. But I think everyone reading this thread can see that you were confused, gradually grasped what we were talking about, and are now just sorta flailing aroundJ-Mag said:I never said anyone was lame or silly. I only said you were the delusional one. Anyway it is the concept of inferring results across platforms because they use the same bus, I called silly.
shiznit said:we cannon compare intel SLI to amd SLI, especially to see the difference between 8x SLI and 16x SLI. Intel cpu's are much less powerful and many benchmarks will be cpu limited, not showing the full performance potential of 16x SLI. the fact that there was up to a 25% difference in the anandtech benchmarks is actually very encouraging and amd performance might be even better when benchmarked properly. also, since intel cpu's lack an integrated memory controller (they suck), nvidia had to build one into the northbridge on the sli chipset and that makes direct comparison to amd sli invalid as well.
Hurin said:Well we finally have a review that debunks the huge increase in SLI-AA 8X and SLI-AA 16X.
Link
Looks like HotHardwares results were a fluke/mistake.
H
Uh, the new review uses 81.85 drivers.Lazn_Work said:More like they did not rebenchmark at 8x with the new drivers (and the drivers provided the boost)
==>Lazn
Obviously, we do not see the 55 - 65% performance advantage we initially reported back on 10/18/05, for the A8N32 SLI Deluxe and NVIDIA's new nForce 4 SLI X16 chipset. In reality, there is a more modest 5 - 15% performance gain over the X8 SLI setup on the A8N SLI Deluxe, due to increased bandwidth for inter-GPU communications during frame blending operations.
