Don't know the first thing about hex editors, but I found something that supposedly works for a problem I'm having. It involves using a hex editor on two exe files.
I installed a USB monitor that I keep all of my sidebar gadgets on. However, the monitor does not run instantly and often times the sidebar will load before the USB monitor does once Windows starts. Because of this, the gadgets will appear all over my main monitor instead of on the USB monitor since the sidebar loads before the USB monitor becomes operational.
I've tried delaying the startup of the sidebar and it works the first time I restart after I setup the delay, but once you launch sidebar it automatically puts itself back on the startup list and then begins launching immediately again.
It doesn't have a GUI with an option to disable from automatically adding itself to the startup list so you have to edit the exe file to change or remove the line that tells it to add itself. It doesn't give you the option at all.
I found a forum where someone had the same issue I'm having, but the solution is to use a hex editor on the sidebar exe file.
http://www.w7forums.com/stop-sidebar-exe-autorunning-t3807.html
The run string for the 64-bit sidebar exe starts at: 0x00005F1C
and for the 32-bit sidebar it starts at: 0x000AC534
Can anyone edit the two files for me? Or give me a step-by-step on how to do the hex editing?
I've already tried a couple of free hex editing programs, but I don't know how to search for those strings.
I can email the two exe files to whoever wants to take a look.
Thanks for any help.
