Can my system support xfire 4850s?
montezuma
I have a Phenom 9600 (4x 2.3ghz), 2x2gb DDR2 RAM, a GIGABYTE GA-MA790GP-DS4H MB, 2x Raptor 74gb HDDs, a DVD-RW drive, an SB Live! 24-bit sound card, and an extra PCI USB card.
The current video card is an 8800 GTS, and the PSU is 630W. Could I possibly support crossfire'd 4850s?
RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Modular LED Power Supply - Retail
Right. I know it has the capacity to support it. But, with all of those components, is there enough available power? I've seen in a few places that with quad core and multiple hard drives that 700w is best. I want to know if I can squeak by.
There are some reviews there that someone is using a 9800 GT in SLI with an E8400. I think you should be fine.. I'm running mine with a 680w PSU (check my sig)
check my sig ;)
I recommend getting a new PSU for the following reasons:
- RAIDMAX PSUs tend to be of low quality. So it may not even be capable of providing 630W of power cleanly and safely. We don't know how much power that PSU can provide cleanly and safely.
- No listing of the combined amperage/wattage on the +12V rail. So we don't know how much of that 630W is available on the +12V rail where a majority of PC hardware now power from.
- Remember that wattage is not the sole factor whether or not a PSU can handle a certain load. How much of that wattage is allocated to the +12V rail is a huge factor whether or not a PSU can handle a certain load.
If you just want enough power to just power the HD4850 CF, then I recommend this PSU:
BFG Tech LS-550 550W PSU - $62
However if you want a lot more headroom as well as stay within the optimal longevity, quieter, and temperature range of most PSUs, I recommend this PSU:
PC Power & Cooling S75CF 750W PSU - $100
Well, I've been underpowered before, and the system would either not turn on or shut off benignly. What are the dangers?
He should be fine as he isn't using a 125w cpu and 2 less hard drives. than me.
