Can I use Optane with NVME SSD?
Sprayingmango
Getting a Rampage VI Extreme and 7900X soon, and was looking at ways to take advantage of Optane which the board supports.
Could I put an Optane module on the board and run it along side my main 1TB 960 Evo M.2? Would it help at all?
I bet most people will tell you that "it's not worth it"
But I also want to know the answer.
Its only like a $60 part and if it's even a bit faster, I'd want to try it.
Optane drives are high I think..I don't know...Probaly just ok with boot on the nvme and just use whatever else you have or can get on sata. Filled this nvme about half way full already anything else hooked up a 1tb wd blue that's still ok. I wanna save the sata Mushkin eco 480gb. alreadly wrote a lot to it. and I swear had some errors. but still works. In case Nvme goes bad...
The little Optane NVMe modules are an ok idea if you only have spinning drives, but the software is a joke. I bought one fully knowing that it wasn't going to speeding up my existing SSD environment, but I just wanted to tinker with it. After weeks and months of tinkering I never got it to work properly, even with Intel remote controlling my PC on a number of occasions trying to figure out what the issues were. When I finally tried to remove it through software it wouldn't remove correctly and I had to blow everything away, remove it, and reformat. I had backups so not a huge deal, but the whole thing was an exercise in frustration.
The Optane has a huge advantage over traditional Flash. It is adressed more like RAM so you do not need Trim, Garbage Collection or erase regions prior write. This can make a huge difference on a steady write load.
Beside that, the 32G module is as fast as an average SSD far below a 1TB M.2
This is different to the larger Optane models like the 900P or 4800X. They are playing in a different ligue especially due their extreme low latency that is a fraction of current Flash and up to 500k iops, see my last benchmarks with an Optane 32G, the Optane 900P and different enterprise class Intel SSD and NVMe as data and cache device,
http://napp-it.org/doc/downloads/optane_slog_pool_performane.pdf
Optane is amazing for zfs, even those little m2 cards can make a killer slog drive for a smaller/home array. Public service reminder that the bigger ones are subsidized by star citizen codes in the short term.
Screw the caching software, just use it like a regular drive and put as much random-read loving stuff on it as you can.
