Can I RAID 2 HDD's that are slightly different?
Nosenuggets45
I currently have a WD640AAKS and a WD640AALS. I'm soon grabbing a WD 1TB drive to replace one of the 640's that is my storage drive. Would it be possible to raid the two different WD's or do they need to be exactly the same?
It's possible to RAID the slightly different WDs
Good to hear. Thanks. Also, can I expect my XP bootup to increase with a RAID 0/1 (which ever is better) with 2 640's? I'd think so but I'm a complete noob when it comes to RAID arrays.
With RAID0, your bootup and load times should be lower than a single WD640 GB drive.
With RAID1, your bootup and load times should be about the same as a single WD 640GB drive.
Thanks again, I might give RAID 0 a try and if I'm not happy, I'll just through my 640 into an external case and call it good :D
EDIT: Woops, i meant to ask if my XP boot times would decrease, durr
The performance gains with a RAID 0 array are measurable, but not overly dramatic in everyday use. RAID 0 about doubles the read speed, but does not decrease the seek time of the drives. Since windows is loading a lot of little files during bootup, the RAID array will not help much for that.
Since you are on the [H]ard Forums, give it a try and post your results. Get a benchmark program like HD Tune or Atto and get the results for the single drive and then the array.
I personaly run multiple SSDs in RAID0 arrays. That does make a dramatic differance in daily use. It's a bit more expensive though.
Don
Heres what you could do.
Since it seems that you only really need 640gb of space as you mentioned R1 being an option.
Do this:
Create your Radi0, but only make the array 640gb.
This way it will use the outermost portion of both disk.
Thus not only making your sequential speeds almost double from a single disk, but it should also lower your access times for faster bootups.
