- Oct 11, 2003
Trying to troubleshoot the cause of random crashes on my buddy's computer.
He's had varying stop codes, 0x3b a few times, 0x7f a couple times, and a 0x7e. Probably a couple others he didn't tell me about.
I tried to figure out the mini dump debugging, and got as far as loading up the dmp files in dumpchk... however it was telling me that i don't have the proper symbols, and i can't seem to find the answer to this problem on google.
Anyway, the dump files are here, if you have some spare time to burn helping me out:
The ones i did open, even though it told me the symbols were incorrect, pointed to ntoskrnl.exe as the cause.
Thanks
Code:
http://files.scottyshideout.com//files/1/dumpfiles/041811-14508-01.dmp
http://files.scottyshideout.com//files/1/dumpfiles/041811-16442-01.dmp
http://files.scottyshideout.com//files/1/dumpfiles/041611-15225-01.dmp
http://files.scottyshideout.com//files/1/dumpfiles/041511-31184-01.dmp
http://files.scottyshideout.com//files/1/dumpfiles/041811-14726-01.dmp
http://files.scottyshideout.com//files/1/dumpfiles/060710-35724-01.dmp
Thanks
