Can I get a decent 24" computer for around $400?
Azureth
I already have a nice 22" Samsung that I bought about a year ago however I am looking to upgrade to a 24" and move this monitor to my second computer. So, is it possible to get a decent one for that price? I'm mainly going to be gaming and web browsing. Keep in mind I'm probably not as anal about it as you guys are, I just need something that will look good enough at the aforementioned things and I'm mainly concerned about ghosting.
I meant Monitor, Doh!!!
Any 2mS panel is definitely a TN so I dont recommend them due to inaccurate colours and bad looking dark scenes.
I'll look up the others for you and try to find the panel types....
The ViewSonic Optiquest Series Q241wb seems to be a TN panel.
A decent discussion on it here
http://www.hardforum.com/showthread.php?t=1262086
The Westinghouse is a VA so is the best of the bunch for colour and viewing angles but you need to find if is fast enough for gaming.
8mS is a general figure, some screens with this rating are awful while others are good.
This thread has a lot of good info on it
http://www.hardforum.com/showthread.php?t=1281444
I noticed the Westinghouse doesn't have a DVI port, how am I supposed to connect it to my PC?
HDMI or VGA.
To use HDMI, you can get a DVI to HDMI cable or adapter for a pure HDMI cable.
You can use a dvi-hdmi adapter and buy a hdmi cable or you could just use a dvi-hdmi cable.
edit: lol two ppl beat me to it. Anyways I was going to get a 37" westy and decided that I can't really afford it so I'm going to pick this monitor up.
I'd say yes as any hdmi cable should be able to support 1080p res.
I have no experience of that cable though.
It needs to be Dual DVI (in one connector) to HDMI, I dont know that single DVI to HDMI exists but best check with Egg to be sure if no one else can confirm.
http://www.officemax.com/omax/catalog/sku.jsp?skuId=21361009&searchString=24"%20soyo%20lcd&category_Id=null
Soyo 24" 24DYLM24D6 Widescreen LCD Monitor
by Soyo | Item # 21361009 | 1920 x 1200 Resolution, 6ms Response Time, 1000:1 Contrast Ratio, 1 Year Limited Warranty
M-PVA panel (8 bit)
VERY VERY NICE QUALITY MONITOR - sorta crappy stand.
Tons of threads on it here - just do a search for 24" Soyo. It's a very nice monitor. I'm happy with mine and for $300? No other deal I've ever seen can touch it.
As far as I've heard, all DVI/HDMI cables are single-link DVI, as the current HDMI spec doesn't support over 1200p anyway. Presumably when "dual-link" HDMI becomes available and common, so too will dual-link DVI to HDMI cables/adapters.
The NewEgg cable should work with no problem. I'd get it at Monoprice as it's cheaper (that's where I got mine), but until you get to much longer cables (say, over 20 feet), in general any (working) cable should work just fine.
The closeout LG L246WP's at CC for $200-$275 I would say were better. ;) If you mean currently-available deals though, I'd agree.
Thats looks really good value, especially for $300.
I heard the Soyo's are changing over to TN panels though, correct? The Westy is starting to get harder to find, but it's a great buy if you do. Same story with the LG L245/6.
http://www.extremetech.com/article2/0,1697,2141605,00.asp
Is the only review I could find for the Westy(main claim to fame is that it is not TN):
4/10 : "poor color and brightness performance in very dark areas, gross usability problems."
A TN panel is not the end of the world. I prefer them to *VA panels. The original poster is already using a TN panel so it should not be that big a deal for him to get another TN. As a bonus it will be faster/less lag/cheaper.
My favorite TN ATM is the Benq G2400W. Very good blacks/contrast, excellent standard calibration for colors and no input lag. Available under $400.
Hi,
I've never purchased any BenQ products before, but this 24" for $389.99 has some pretty good reviews.
BenQ G2400W
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014158
+1
I ordered my BenQ from Buy.com the other day for 389.99 no tax and free shipping plus I had a some money off Google Check out coupon for even more savings. Since I am in NJ, Newegg nails me 7% sales tax and it costs $17.24 for the shipping for the same item. Everything I have been buying as of late, newegg has not been the choice supplier. Microcenter due to the sales tax issue (3.5% urban enterprise zone) and the items I was looking at Microcenter was cheaper by a good enough margin to make the drive there. However there were many times where Newegg with the sales tax was cheaper than most other places. Also Micro center seemed to have some insane deals going on to make it worth while for the drive there.
As for the G2400W while looking for a 24 inch LCD, I didn't care about TN panel pitfalls like viewing angles since this is a Desktop monitor only. I do not play console games in this room. So many or those issues do not affect me. There was alot of good buzz generated on this product. It's price was right in comparison to other similar models. There is quite a topic thread in the displays forum about the monitor. So it seemed like there was something to go on.
Ironically, the G2400W was not my first choice. I was thinking about getting a Samsung 245BW (good choice as well) cause I never had a problem with Samsung products. I am typing this reply via a 940BW 19 inch widescreen. My TV in the living room is a 40 inch Samsung. My wife and I love the picture and the viewing angles as well. However, the BenQ model seem to edge out the 245BW by a few hairs including the price to make me jump on it.
BenQ G2400W Buy.com link for the lazy :)
Well good luck with your monitor purchase decision. The main thing is find something you will be happy with.
shaggy
viewing angles aren't the only pitfall to TN - color reproduction is slightly worse.
Typically lag isn't an issue at this time regardless of panel choice. My 6ms M-PVA Soyo has no noticable ghosting or lag in any game and at the last LAN I went to with my 24" soyo I was first place in a Far Cry tournament so I don't think the 6ms lag is any issue.
Hey there,
For your requirements the BenQ G2400W will do exceptionally well.
It is a fast 5ms panel with zero input lag. Color is accurate and the viewing angles are as good as any TN I've seen. The DVI and HDMI ports work spectacularly, so it is more than happy with your PC on DVI and a console on HDMI.
So far, I have tested three monitors: BenQ FP241VW, Westinghouse L2410NM, and the G2400W, and I'm still hard pressed to figure out which one is best, but the G2400W is definitely the fastest both in response time and input lag. The Westinghouse has the best upscaler, and the FP241VW has the most connections.
The G2400W is the best gaming screen though. I've cloned this with the FP241VW on Gears of War, and even though the FP241VW is capable of more vibrant and bright colors, the G2400W was heads and shoulders more accurate in color representation.
Text is pretty sharp as well for web browsing, and since it's not overly bright, eyestrain is not an issue. Backlight bleed is extremely hard to spot.
For those who are wondering, response time is different than input lag. Response time is the speed of the pixels, and the input lag is how long the monitor waits before it responds to user input or shows something on the screen.
While the panels in the FP241VW and the L2410NM are MVA panels rated at 6 or 8ms, dark color response of these is not nearly as good as the G2400W. And since the G2400W does not use overdrive, there are no ghosting or inverse ghosting issues, and input lag is non-existent.
One thing I can say, is that compared to other 24" TN panels I've seen, the G2400W is my favorite.
Regards,
10e
Don't get the Westy L2410NM for gaming. It looks great but has way too much ghosting and input lag.
I can believe the rest of what you say, but a 6-bit TN panel (in the G2400W) is really better than a 8-bit VA panel (in the FP241VW) in color accuracy? Have you actually measured that with a colorimeter or the like? And are you talking about just out-of-the-box or calibrated?
