Can I flash my MB without a floppy
next-Jin
If I have the file at C:/FileName.ROM can I flash it? I dont have a floppy bc I never use it,
thanks in advance
I know you can make a boot cd to flash with or you can use a usb flash drive if your computer can boot a usb device.
some companys have windows based bios flashing utilitys for their motherboards (like MSI), but theres a much higher chance of bricking the bios. thats why some people wont do it any other way apart from floppy.
you're best off looking at the motherboard manufacturer's website and seeing what utility's they've got to download.
I have heard some web based utilities being extremely risky... I am going to try USB myself.
I've been using Award's WinFlash for years (Abit KT7A-RAID) with no problem. Actually just used it on my friend's new Fatal1ty AN9 within the past couple weeks, and used Abit's new Win-flasher (included with the Guru stuff) on my own Fatal1ty AN9 last week.
DOS floppies follow the Keep It Simple, Stupid philosophy, but even Dell is using Win-flashers now. As long as your system is stable, a Win-flasher shouldn't be an issue, but I wouldn't recommend it if you're having lots of problems (which you're trying to fix via a BIOS flash).
Been using MSi windows based flash for a good long while never had any issues!!
I've used Winflashes almost exclusively and never had a problem. I don't do an Internet update though, I download the bios I want right to the HDD and then flash from the HDD using the Winflasher program as supplied by the board manufacturer. I have used Winflash also where applicable and it went smoothly.
