bullshhhhet
the 4870 will blaze and the 4850 will just adda bit of ummff to the main card being 4870..
if you get more 3dmarks than a stock 4870 adding a 4850 than how does it slow the 4870 down.. you just got more fps added on to the first card in gaming. !!!
so 100fps from ut3 gamewith one 4870
and 2 4870's in cf would get ya say 170 fps
adding 1 4850 + 4870 would get ya say 145 fps
ok im looking at it a diff way.
if 1 cards gets you say 10 fps in any given game. and 2 cards get you say 15fps . tou gained 5 fps. adding a nother card. so your saying im gonna get 9fps with both cards not being the same.
i just o/c my 4850 825/1200 mhz now if i add a 2nd 4850@ stock what do i get ?? both cards run a speed of stock ? tell you what i just got 16000 3dmarks on the o/cd card from 11838 marks @ stock
the only diff between the 450/4870 is faster clocks thats all.i will throw in my 2nd card in cf run a 3dmark demo and see what i get.. i will bust over 20000 thou marks.just by adding 2nd card. plus i think my overclocked card just took 10% off the lead the 4870 has over 4850. Maybey more .
Both cards need to be running at the same speed. Since the 4870 is significantly faster than the 4850, it will need to clock down to 4850 speeds to run in Crossfire, making the effective performance equivalent to two 4850s in Crossfire. While two 4850s do seem to be faster than a single 4870, it defeats the purpose of getting the 4870 in the first place since two 4850s could have been bought instead for a significantly lower price.
Also, please use proper spelling and punctuation in your posts. It makes them much easier to read and understand.
