Can a PS/2 Keyboard port KILL?
water1
Hello,
I had a keyboard go bad on a computer so I took a good working keyboard from another computer pluged it into replace the bad keyboard but now the new good keyboard did not work on this computer. When I put the good keyboard back on it's original computer it was now dead also? What is going on ? Can a keyboard port go bad and start killing keyboard's ?
I suppose it's possible - a short circuit could put full 5V on another line but I'd sort of expect the data and clock lines to accept 5V without damage. It wouldn't work, but it shouldn't fry anything.
It's also possible that 12V or more got onto the 5V line. It's a pretty benign port otherwise. Google the port pinout spec and then check the port with a volt-ohmmeter to be sure. You'll need a logic probe or oscilloscope to detect a proper signal on the clock and data lines, but a VOM will tell you if you've got constant high voltage where it isn't supposed to be. You can also check the ground by testing for zero resistance between the ground pin and another ground point on the MB (like a shield).
you better put it down while you can. when PS/2 ports go bad they'll take out your entire familiy if you give it the chance.
I had a PS/2 port die on me and it took out the keyboard that was plugged into it. It didn't damage any other keyboards, but I liked that keyboard.. It was a black ergonomic keyboard from Belkin.
I actually had this start happening with an old eMachines motherboard. Come to think of it, that was a terrible experience. The audio ports got finnicky, then quit entirely, and pretty soon, the PSU had died and I bid my trusty computer farewell. :(
i had a weird one with my old SB live back in the day. the joystick port on it gave out. no reason or warning, just refused to work. thing is i figured it was the nice sidewinder joystick i got off a friend. so i took it apart and then couldn't put the bastard back together again. THEN i figured out it was the port.
I have a MSI board and when the PS/2 ports went, they took out the USB controller also. The board still works, but I can't control it at all :mad: .
My motherboard was an MSI also! :eek:
The onboard NIC also died on it. I'm still using it in my current rig though. yay for USB keyboard and mouse! They actually work in the BIOS too! I was suprised!
