Came home from work, PC is broken..help?
Rizen
Okay, so I have a weird problem and I'd like some help.
Two days, I had this problem: http://www.hardforum.com/showthread.php?t=1384895
Cliffnotes: tried to install 2x Sapphire 4850s, the top card was not getting enough airflow and hit 100* C a few times, so I uninstalled it and RMA'd it.
That night, I removed the second 4850 and my PC was okay. Played about an hour of Left4Dead, browsed the internet and went to bed. Woke up yesterday and used my PC, all was well, and went to work leaving it running.
I came home last night and it would not wake up. The monitors were in low power mode but it was unresponsive, so I rebooted it. That should have been the first sign. So I get into Windows, browse around for about 5 minutes and it BSODs. Hm, figure it must be a fluke, go into the BIOS and raise the voltage a small notch on the CPU. Reboot - still BSODs. I figure it must be because I never uninstalled and reinstalled drivers after removing the second 4850, so I go to reinstall my 4850 drivers. It BSODS again, during reinstall.
Fast forward about 30 minutes later, of constant BSODs. I figure damnit, the drivers must have mucked up my PC. So I format my hard drive and go to reinstall Vista, which is a huge PITA. It BSODs during the expanding files section of reinstalling Vista!
So I turn the CPU back to bone stock speeds, and now Vista reinstalls fine.
I reinstall all my drivers, set it back to 180*21 for 3770MHz, and it immediately BSODs again going into Windows. If I run it at this speed, or even 3.4 or 3.6GHz, it BSODs in Windows and sometimes doesn't even make it in. This is a speed that was stable for almost a week of constant use, 6 hours of Prime95 blend testing, etc before yesterday. I didn't change anything else in the system besides trying to run the two video cards.
I don't know what else to try. Here is what I have tried:
- Raising voltages (up to 1.45vcore CPU and 1.4v QPI Vcore), no help
- Lowering voltages, no help
- Reseating all my RAM
- A different video card, in case the one in the system was damaged from the heat
- Reseating the power connectors, except the 8 pin CPU one which I guess I'll try tonight
- Reinstalling Vista
- Unplugging one of my SATA hard drives
The memory will pass a standard 2-pass Windows memory test but I think I ran it at 1066MHz.
The system was running FANTASTIC before yesterday.
The only other anomaly I can see is that it thrashes my disks a lot more when overclocked now than at standard speeds.
Any ideas? I'm guessing something is damaged, but from what? Could a few minutes of having a video card at 100* C damage my board?
I guess I can try a different PCI-E slot for the video card and reseat a few things, but I think it's a memory issue.
The BSODs are usually the following:
MEMORY_MANAGER
SYSTEM_SERVICE_EXCEPTION
some error with NTFS.sys
Thanks guys.
System specs are in sig.
