Calling All You ATI Guys . . .
Hmmm . . . Well mine seems to work in Vista. Go ahead and give it a shot. Worst thing that could happen is that it doesnt work and you would just have to uninstall it. but mine works fine. :)
I will also suggest using Rivatuner to adjust the fan speeds of the cooler on your card. That way you can keep it nice and cool. :cool:
Yup, already got that. Whats a good temp to shoot for on this card? I don't want to computer to sound like a jet taking off 24/7 lol
I have a 3870 with a double slot cooler. I generally try and keep mine below 60°. I guess Im not really sure what the thermal limit is on these cards.
great thanks for helping us out!! What kind of card are you folding with?
Right now I have a 3870 going, but I'm trying to downscale by building a shuttle system and have a 9600GT for that. Low power/heat, sff and efficiency were the goals. ;)
My 3850 has been crunching for hours at 86°..... better get that rivatuner going, it´s kind of worrying. It seems awefully hot in a not very hot room...
Yeah, the stock settings are crap. Do you see 100% load when you are doing it?
Yep grab Rivatuner. You should be able to cool it down quite a bit.
stang - you were probably addressing this questions to nakedhand but my GPU is either about 50% or about 90% depending on the WU i get. The bigger WUs for me use more of the GPU because it takes less CPU power to "feed" the stream processors. It requires a powerful CPU to completely utilize the GPU core on the smaller WUs.
If some of you are interested in the type of WU you are getting try downloading FAHmon. This program will also estimate your PPD if your interested.
Happy Folding!
GPUs can take a surprising amount of heat.
Like into the 90s and 100s at times.
So I don't have an ATi but I just started doing this anyways.
It says my next frame ends in 20m and my WU ends in 10days is this normal?
I have a Q6600 at 3.4ghz
Just added my folding to the chimp challenge, good luck guys,
Oh how do I work out how many points per day I am doing?
Alright, I got the gpu up and running. I too am interested to see what my PPD is.
Watching in display is funny, I dont know why
First off, thanks for joining us Plaguebringer. Thanks for helping out the [H]ardest team in the world!! :) If you dont have an ATI GPU then you cant use any of the GPU clients, however that Q6600 is a bad ass CPU and the choice of most of our folders. (I wish I had one!!:D)
Anyway look on this website : http://folding.stanford.edu/English/DownloadWinOther
There is a 5.92 SMP client. This is what you would want. This client will net you probably 2000-ish PPD at that CPU speed. This client will only use 2 cores of your Quad but I know some guys in the DC forum that will gladly help you set up 2 SMP clients on your computer so you can use all 4 cores if you wish.
Which client did you download? I cant see that CPU working on a single WU for 10 days. Try and get one SMP client running first and then work towards a second if you wish. If you need some help with your SMP client config post in this thread: http://www.hardforum.com/showthread.php?t=1297404
There are some very "Quad knowledgeable" guys that can help you out. If you have any questions I'd be happy to try and help out as well.
Happy folding! :)
Edit: Here is a thread on the folding forum that walks you through the SMP client setup. This is what I used to setup the client on my Opteron.
http://foldingforum.org/viewtopic.php?f=8&t=1783
If you go here: http://fahmon.net/download.html and download the fahmon software - This is just an exe that you run that tells you which type of WU your working on and it estimates (fairly accurately i might add) your PPD. Its a pretty neat little program.
Thanks for helping us with the challenge!! Cheers!
Awesome. These ATI GPU sure can fold! They are bringing in quite a few PPD for me. See the above post about figuring your PPD.
Not sure what you mean about the display being funny. :confused:
I was talking about the rightclick - display option. I don't know why, just founf it amusing for a few seconds...
Anywho, the Folding at home doesn't appear to have a FAHlog.txt file. I guess I need that to monitor my folding status. Any ideas?
Look a couple posts above this one for the link. Download fahmon. It will tell you your PPD and you can view the FAHlog.txt file.
Mine ended up C:\Documents and Settings\<user>\Application Data\foldingsomethingdon'tremember\, so look around in your application data folder and see if it ended up in there.
I started the graphical folding F@H because of this thread. ;)
This is actually a neat program. It's gonna take a while though to finish completely.
I really should get an ATI card. I like my 8600GT, but in games and other graphical applications it tends to have problems (lag, slowdown, weak AA, etc.).
Thanks for joining us Red. Remember to use the username [H]ardApe if you want to contribute to the Challenge. ;)
Know any friends that have ATI cards (or Quads) that could help us out in the challenge? :D
Will 2 3870's on a crossfire computer work with this project? I have never done anything like this and I am not too software aware of what needs to be done on my end. So if it will work I would need a little help in setting up this. But if you could use private messages and not clutter up the post with my dumbness.:D
Ok, got the fahmon working :) thanks for that. Using the GPU it tells me that I am getting 1900PPD.
Now can you tell me, can I run both the SMP and the GPU2 client at the same time? I have got a Q6600 and a 3870 GPU.
the GPU client uses 1 core, so you should be able to run a single SMP client on the other 3.
Tobit uses this set-up and it works well for him.
Alright, found the .txt file under the appdata folder. Thank for that.
I am at 2029PPD! does OC help speed up the process?
Also, Everyone is saying this should only take one core. This runs my 6400 at 60% on both cores. AMD issue?
do we have to update to beta to be of any use???? im still using 5.02 or something like that
I wish I could be folding with my 1950GT... I was looking for a long time for the right GPU client, but couldn't find it. (Maybe someone can point me in the right direction?) Until then, I'm folding via CPU with c2d e4300
What are you trying to fold with? A CPU or a GPU? Different clients are for different things. Some of them are for single core CPUs, Multi-core CPUs, and graphics cards.
If you have a ATI 2000 or 3000 GPU I would highly recommend trying the 6.11 GPU client!
If your interested in helping let me know the specs of your system and I can help you get started. ;)
Well thanks for helping out with your C2D!! Are you folding for the [H]ardApe?
Unfortunately the old GPU client is no more. :( There are some fairly good deals on some of he 3750's however.
Another 2000+ PPD for the [H]ardApe!! Thats great! :D
Hmmm . . . With the load balancing that your CPU does 50% on both cores would be the equivalent of 100% of one core. The other 10% may be other background processes? Possibly anti-virus or something?
well i got a quad core, and im folding already for another team. Came across this so yeah why not give it a help :D
Well I think that Stanford recommends not using to graphics cards in the same system but I think people have done it. I only have one 3870 so I havent tried this either. Try getting one client up and going first and let me know if you have any problems.
Might want to grab rivatuner to adjust your fans speeds and fahmon to monitor your folding progress. What kind of CPU do you have?
Well we would be open to the help, but if you are already supporting another team I will leave the decision to fold for Team 33 up to you. If you want to help us with the Challenge just set your user name to [H]ardApe and your team to 33. If you have an ATI GPU I would recommend putting it to good use, as it seems you are with your Quad!! :D
Team 33, right?
Been folding for [H] for ~2 or so months
Wow guys......it's great to see all you going the [H]orde and folding for the Ape!!!
Thank you all so much for helping out!!!!
Fold On and Fold [H]ard!!!!
No problemo! I'm enjoying this so far. Working on getting an ATI card though for the GPU version. Changed the name too!
tried to help you guys, but the F@H client messed up my crossfire profile :/
