Calling all gurus: multiple sudden mobo deaths
Lotvog
Mornin' chummers!
Long, lonnng time reader, first-time poster.
I've got a dilemma for you experts. Been buildin' PCs for well over 13 years, and I've never seen anything of the sort.
I've recently been tasked with backing up/cleaning/stripping excess hardware/formatting ~25 older clone systems during my downtime (P3/early P4s), then setting aside the best 10 and donating the rest to a local charity. Most of them have booted up just fine, and all's going swimmingly, having completed ~10 or so;
However, of those originally booting up OK, after following basic maintenance outlined below, 4 of them power up but no longer POST no matter what I've tried. None are emitting beep codes. Here's the basic scenario:
  • Remove side panel, boot the system into Windows, back up files, format the system.
  • Run memory diagnostics and HDD diagnostics overnight. If defective, replace with known-good parts.
  • Disconnect all cables, dust the insides using compressed air.
  • Replace dead/dying PSUs/fans.
  • Remove excess RAM DIMMs, leaving the system at a minimum (256/512Mb).
  • Reconnect all cables.
  • Boot: if no POST, cut power/remove cord, reset the BIOS w/ the CLRRTC jumper. Restablish power, boot.
  • If still no POST, cut power/remove cord, remove CMOS battery to force the reset. Restablish power, boot.
Bam. Of the 15 or so systems processed thus far, 4 "dead" systems (and a 5th with a bad BIOS checksum following the reset). There are no similarities, not even the CPUs/mobos/chipsets - the only common thread is me.
I have only 1 hunch, and it's a long shot: dead CMOS batteries. All these systems are 4-5 years old on average, so it's remotely possible that the battery is already failing or on a low charge, and/or that my manipulating it (even with gloves) would have caused the remaining charge to leech out, but... all 4 of them? Otherwise, while there's a fair bit of static electricity in our office, my worktable is a static-free zone (grounded mats/straps, esd coating, the works).
I'm really at a loss, and possibly worse, my geek cred is severely hurt.
Halp? Thank you kindly in advance.
Hmm, could try buying some CR2032s to replace the batteries, that would at least rule out one thing :p One day I'll tell you the story of the 4870 that killed motherboards :(
If the order of your steps is correct. you are unplugging everything then using compressed air to blow out the dust. If this is true you might be filling all the plugs with dust causing this problem. If they all work then you do something with different systems, the only common denominator is you.
or mabey bad power?
its a long shot but mabey the plug or something else your using is bad, causing a power problem and killing them?
I would expect, but couldn't guarantee, that a system with a bad BIOS battery would still POST. It would simply have lost all of its settings. I could be wrong. Does a system still boot with the CLR jumper set?
If that's true, it could be your overnight diags acting like a burn in killing something. These are pretty old boxes if you're working with P3s. Some of these things may have marginal aged components (capacitors, dried up TIM) and they are simply dying at an accelerated rate due to the loading being placed on them.
I doubt it's your power.
Is the compressed air from a "normal" shop or "garage" air compressor ? If so and a "dryer" (trap in the air line to catch water, painters use them) is not installed you are spraying water droplets all over the boards.
If you are using "canned air" - nevermind.
Thats my wild ass guess as there is nothing else you are doing that I see that accounts for so many boards working fine one day and dead the next.
Why do people think using compressed air is a good idea? I have seen this destroy several computer systems.
IF YOU ARE GOING TO CLEAN OUT COMPUTERS USE A VACUUM CLEANER.
Particles accelerated by compressed air is about equivelent to sandblasting your motherboard.
Would you sandblast your components? Then why would you use an air compressor.
I've seen some computers with a BIOS option that won't let the PC boot if the side panel is off. (Dell's I think). I know the PC's at my work have that enabled. Seemingly once you installed the sidepanel back on and 'clicked' it into place, it would almost act like it activated a small switch which would then allow it to boot.
Just a shot in the dark, but try with the side panel in it's original position.
"•Remove excess RAM DIMMs, leaving the system at a minimum (256/512Mb)."
Just a hunch, but I think this problem has something to do with the RAM/removing of extra DIMMs etc...
This is where I would start, but I would imagine it's already been tried.
I wouldn't be surprised if ESD killed the boards. It's pretty rare, but some times the conditions in one room are very conducive to ESD. You don't need to feel a spark to have an ESD discharge event.
I would say that you can use a vacuum to suck up dirt, dust, or hair around your computer on the outside case and on the keyboard. However, DO NOT use a vacuum for the inside of your computer as it generates a lot of static electricity that can damage the internal components of the computer. If you need to use a vacuum to clean the inside of your computer, use a portable battery powered vacuum or one that is ESD designed to do this job.
I know from experience that it is not the best of ideas to use it inside the case or around the board trust me.
I also agree on the compressed air it can help with cleaning fans and PSU fans but directly off of the board is not a grand idea.
KM
