Originally posted by Eelpout
Nexx and Iconz1,
Do you think going to Windows ME would be a better alternative?
I read somewhere that WIN XP will manage the memory better on slower computers that have less memory?
I can O/C to 450mhz from 400 but I get Prime95 errors after about 45 minutes. Will that help?
Thoughts on the Voodoo 2 and the new O/S?
Originally posted by [BB] The Pirate
Eelpout,
Windows XP will run pretty sweet on your set up. Since your rig is a little older it will manage the memory so that aplications and games will run at peak performance. Windows XP will also take your 64 mb of ram you have an make it run in "dual data' mode; which in the end will be sweet for you.
That system should score at least 20K in 3DMark01 and about 8k in 3dmark03. Do some benchies and let us know where you stand with the numbers.
Nexx and Pirate Thanks. With your advice in mind I will go for WinXP and give you an update.
Nexx, I do have a 256 MB stick of PC100 Ram...the reason why I run the 64MB PC133 is so I could overclock better.
Nexx, have you used a Voodoo 2 with Win XP and how did it work out?
Pirate, I will try to benchmark 3DMark2001 hopefully it should increase by 20 pts or so hopefully...
Originally posted by TheGamerZ
Dude....
They're all fuckin with ya, XP wont run for shit on yoru system.
It requires 256mb of RAM at least in its written requirements. Plus, with little to no official support for your video card.
To be honest, you're better off sticking to 98SE, at least until you buy a whole new system
Originally posted by Iconz1
What's wrong with you Pirate? That's the kind of crap I'd expect out of someone from Edina, not Burnsville.![]()
Anywho, here's the sys. req.- http://www.microsoft.com/windowsxp/home/evaluation/sysreqs.asp
It basically says....good luck.
EDIT: Sorry Eelpout, but WinME is not a wise choice. The worst Microsoft OS EVER!! Try Linux, it will run fine if you are in the mood for a change.
Originally posted by Foz2001
"Pirate, I will try to benchmark 3DMark2001 hopefully it should increase by 20 pts or so hopefully... "
20 points, u might even get 25 if your lucky.
Dude....
lol you guys are cracking me up...
ok...it took 2 hrs to reformat...and now i'm waiting for the SP1 updates to finish installing...it's taken about 1 hour for that so far....after that the security updates...
thx for your support...
long live 440BX chipset.
we'll keep you posted...
Good Stuff Foz2001...
Which is faster...my CPU rig or your car (see your sig)?![]()
haha whatever pal i dont display my pc cuz im not proud of it, if u have to ask..
p4 1.4ghz
512mb pc 133
Radeon 9600 pro OC' to 550/350
As for my car beating your computer, i simply have to swirve and crush the pos. This forum isnt all about computers there is a "car" section.
Hey Foz2001, I was only messing with you, I'm sure your car gets great gas mileage and is "rusty but trusty"...or a "beater with a heater", and it's going to be a great collector's item in about 2 years....just like my RIG.
I'll make a deal with you, I'll scrap my rig, you scrap your winter beater, and we both upgrade
BTW...These PSoD (Pink Screen of Death) with checkers went away after I rolled back to the stock drivers. Thanks everyone for you help and humor.![]()
