alg7_munif
- Oct 9, 2006
Do I need to change anything in WIndows or the quad would work right away after the swap?
Mine worked right away but some BIOS's might need to updated.. Just ensure that you are flashed to a current BIOS version.. 680i motherboards come to mind.
On my EVGA 680i, I had to enable the other 2 cores in the BIOS...I don't know why, but there is an option in the 680i BIOS to use one, two, three or four cores....Like someone is gonna get a quad and not use them all..![]()
Ah ha......That makes sense..If you have a known bad core you can shut it down to preserve the stability of your system.
