if you OC, you will be fine...
Sig says your 6850 is @ 3.6ghz
wondering if the gtx285 works fine with the e6850 cpu or if the cpu would be the limiting factor?
deciding if this is even worth the upgrade from a 8800gts 512 card right now.
ah cool thanks guys
yes i'm still running @ 3.6ghz
debated on upgrading to a quad but i don't think it's worth the $.
i couldn't really get the cpu stable above 3.6 or i would have o/c'd it more![]()
