The stars have alligned themselves and I will finally pull the trigger on my mid to top end gaming machine. I will be reusing my old case (generic white ATX), old IDE CDRW drive, and IDE hard drive just to get the system up and running around x-mas I will upgrade those components. So here is what I plan on buying,
G0 Q6600 from Clubit
Going quadcore because I hate waiting for decoding in winrar, and generally run multiple apps. Some futureproofing compared to dual.
IP35 Pro from Clubit
Uguru, P35 chipset sold me, I dont need SLI, from what I read there are many options to tweak, and Im a tweaker.
Mushkin 4-5-4-11 2GB 800mh Ram from Clubit
CHEAP!! Timings are tight, figure I can unlock the ram if it holds my G0 back from overclocking down the road.
XFX 8800GTS Extreme 640mb from TigerDirect
Cheap once again, I wanted 640mb for alittle future proofing and 21" monitor res.
Xg 600W PSU purchased a few months ago from buy.com
Bought it to replace my dead PSU in my old PC, no reason to purchase a new one.
Total price $970-110 rebates= 860-20 cashback from discover for tigerdirect purchase,
So basicly $840 for components. Leaves me $160 once receiving rebates to go get a Seagate 7200.10 250 or moreGB sata drive and 20x Sata DVD burner, I will also upgrade the heatsink and buy a new case once getting the rebates back.
So what do you guys think, Q6600 G0 w/ IP35 Pro using Mushkin ram going to work together? Any suggestions apreciated, total budget should be less than $1000 for MB, CPU, RAM, Video, H/D, and DVD.
Thanks,
Charles
ps I want to buy this on saturday at the latest, that is when the xfx rebate runs out that gets me the card for $330 after rebates and discover cashback.
Thanks,
Charles
