Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If you need surge protection, it makes no sense to go cheap as it wont work well or long and you just blew up a $1000 computer by saving $8. Good units can be found for $15 or so, Stay away from the $7.99 ones. Everything you need to know is at the link below.
They do wear out, get a UL listed one, when the on/off light starts flickering , throw it out or use it just as an outlet expander as the surge protection is worn out.
