- Nov 22, 2004
I am in the position to go ahead and purchase a external solution for my computer but am not sure what to do. I want a external hard drive STRICTLY for storing the images for all of my drives. I just want to store them externally in case anything ever happened to my computer (lightning, drive failure, etc.).
I do not know which solution I should go with.
A. Buy a prebuilt external solution (eg. the WD My Book). I have read those have somewhat of a high failure rate though (no matter what manufacturer).
or
B. Buy a hard drive and an enclosure. Recommend me an enclosure if you think that is a better route (I read the Antec ones are popular).
I am going to need something which is 500GB. The way I figured it option A and B are both around the same price.
I am just looking for something which is reliable. This won't be something which runs 24X7. I will only have it hooked up when I am copying over my images.
Ideas? Suggestions?
Thanks!
or
Ideas? Suggestions?
Thanks!
