Buying a new computer, need opinions!
Hello there.
I'm about to buy a new PC and I would like to have a second opinion around here.
I'll buy the system on NCIX. I've started from one of their promoted gaming setup and changed some things to save money.
My main concerns are : 1. Is this system build any good? 2. Are there blatant compatibility issues between pieces? 3. Are there anything to be done to save some money and have approximately the same power?
Here the NCIX link with every pieces : http://pc.ncix.com/ncixpc/ncixpc.cfm?uuid=1BC63B2A-725A-433E-A1E4D736F5F51CBF-5564864
And, of course, here are the usuals questions answered :
Gaming. (looking for a PC that can run games maxed out for some time)
1800 (before tax and shipping)
Canada
Well... Everything. PC casing, cpu, motherboard, graphic card, power supply, heatsink, dvd reader (no blue ray needed), audio card (needed to support my headset, nothing too fancy, but I need an headset AMP), HDD, SSD...
None
6) Will you be overclocking?
Mildly
Two monitor 22" running mostly at 1920x1080
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB3.0
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, windows 7 64 bits
Can you build a PC or are you looking to buy a gaming PC from a vendor?
The quality of that PC is good but just really overpriced (even without factoring in labor costs) and actually overkill due to the following reason:
1) That motherboard is well beyond your required needs. I highly doubt you'll use even half the extra features that's found on that Gigabyte motherboard. You'll be fine with a far cheaper motherboard like the Asus Z87-A.
2) With current Intel platforms, there's little to no noticeable performance increases with RAM speeds higher than DDR3 1600. So no need to spend extra cash for DDR3 2133 unless for e-peen purposes.
3) You have not mentioned any plans for SLI. As such, no reason for such a high power PSU. For taht planned setup, you would be fine with a solid 550W PSU like the Seasonic SSR-550RM.
4) I'd go with the more reputable Samsung 840 Evo SSDs over that Kingston.
5) IMO, that Coolermaster case isn't worth the money as there better quality and/or better cooling cases out there for the money:
$100 - NZXT Phantom PHAN-001BK White Full Tower ATX Case
$100 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$110 - Antec 1100 ATX Case
$110 - Corsair Vengeance Series C70 Arctic White ATX Case
$120 - Corsair Vengeance Series C70 Gunmetal Black ATX Case
$120 - Corsair Carbide Series 500R ATX Case
$130 - NZXT Phantom 530 Black Full Tower ATX Case
$144 - Silverstone RV03B-W ATX case
$144 - Silverstone RV03B-WA ATX case
$150 - Corsair Graphite Series 600TM ATX Case
$160 - Corsair Obsidian Series 750D ATX Case
$160 - Corsair Special Edition White Graphite Series 600T ATX Case
$170 - Corsair Obsidian Series 650D ATX Case
$170 - NZXT Phantom 630 Gunmetal Full Tower ATX Case
$170 - NZXT Phantom 630 White Full Tower ATX Case
$230 - Silverstone FT02B-USB3.0 ATX Case
$250 - Silverstone FT02S-W-USB3.0 ATX Case
$245 - Corsair Obsidian Series 800D CC800DW ATX Case
Thanks for the answers!
I went for the NZXT Phantom 530 Black Full Tower ATX Case casing instead. I liked the 4 fans setup and overall looks of it (while saving almost 100$). I'll probably settle with the samsung also, after reading on both of them the choice seems simple!
