XFX. Just because they have a bad ass warranty!
XFX does have the excellent double lifetime protection program.
http://www.xfxforce.com/en-us/Features/DoubleLifetimeWarranty.aspx
What kind of power supply are you plugging these 2x 4890 into?
the one in my signature. 750watt! i think its gonna be borderline
so i bought two 4890's! the brand HIS
the gpu test on crysis scored an average of about 17 (crossfire disabled)
crossfire enabled got me an average of about 26 but tree's for example in the distance and alot of other things in the backgroud "flicker" this doesnt happen when crossfire is disabled!??!!?!?! why could this be?
How am I getting 32fps average on the GPU test in crysis benchmark with everything as high as it will go including AA @ 1680x1050 with one 4890 and you are getting 17? What resolution are you running at?
umm dunno wat happened here, just lived my life for 24 hours, came back to my comp! ran the test again the gpu test that is and scored avg 37fps crossfire disabled! so my bad
Umm.. 6GB of RAM on an AMD Dual Channel Platform?
That means you're not running Dual Channel (3x2GB sticks).
Take one stick out (or purchase another single 2GB stick) and install a 64bit O/S.
so you are running 2x 1gb and 2x 2gb? if so then yeah you should be able to do that but check your mobo info to be sure.if i get a 64bit os cant i just leave it? 2gig in the 1st channel then 4 in the second?
you cant have 1x 2gb stick and get dual channel. it takes 2 sticks hence the name "dual channel". in other words both slots of a channel need to have a stick of the same size in it.i got 1x2gig stick in the first channel and 2x2gig sticks in the 2nd channel was told thats wat i should do...just need the 64bit OS
yeah you won't get proper dual channel operation with 3 memory sticks. It just doesn't work that way.
Nice video cards btw, but aren't they noisy as hell?
