buy the harddrive and external enclosure separately?
On modern systems, yes. Hot plug/swap is part of the AHCI specification. Activate AHCI mode in your system's BIOS if you have not done so already, and you're good to go.This is kinda off topic here, but if you have an external SATA hard drive, can you plug the drive in and off while the computer is running, just like you would with a USB external drive?
It'll either boot successfully, or it'll blue-screen. If it blue-screen's then you just reboot, go into bios and disable AHCI so you can troubleshoot. It may require a simple registry hack, or an AHCI driver install/re-install.[LYL]Homer;1034265315 said:Does activating AHCI if it has not ever been on ever cause any stability issues?
Most likely STOP error in that scenario is STOP 0x0000007B. Vista has built in support for AHCI, so a Vista install should have an AHCI driver to plug in without needing the user to install one. This is not the case with XP. Just another reason why I have not looked back on Windows XP.It'll either boot successfully, or it'll blue-screen. If it blue-screen's then you just reboot, go into bios and disable AHCI so you can troubleshoot. It may require a simple registry hack, or an AHCI driver install/re-install.
Another vote for building your own, especially if you can scoop up a drive with a 5 year warranty.
