Business computer build help for parents
m_cochran
Business use... invoicing, spreadsheets, email, data backup
$800 all included
3) Where do you live?
Lake Dallas, TX
Case, CPU, Motherboard, RAM, SSD, Hard drive, Memory, DVD drive, OS
n/a
6) Will you be overclocking?
no
19" widescreen already have
within the month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
would like RAID for data redundancy
No, would be included in budget, thinking 7 Professional
Would be willing to pass on the SSD if that would make a difference.
No it doesn't. Again for this case, it doesn't make sense to build a PC when you can buy a similar performing and slightly lower quality for half the price for a usage scenario that isn't particularly demanding.
Wait a minute, what do you mean by "data backup"?
Well from reading more and researching I think the best solution for them would be a redundant hard drive setup. That way if one hard drive takes a crap or something gets erased by mistake their is still another copy.
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
ASUS M4A88TD-V EVO 880G SATA6Gb/s USB3.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131646
G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333
http://m.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=Gskill 4gb
Video
Integrated Radeon HD 4250 128MB SidePort Memory comes with mobo
Four Samsung F3 1TB RAID 10 or 0 1: Capacity: 2TB
http://m.newegg.com/Product/Product.aspx?Item=N82E16822152185
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24XDVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
SeaSonic S12II 520W 80 PLUS
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
APC BR700G 700 VA 450 Watts Back UPS RS LCD 700 Master Control
http://www.newegg.com/Product/Product.aspx?Item=N82E16842101381
Antec Three Hundred Illusion
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Rosewill Wireless USB 2.0 802.11b/g/n w/ 5dBi Antenna
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166056
There you go OP
Get a pre-built PC from walmart or dell. Run it ragged and use the hell out of it. You can cheaply upgrade JUST the hard drive later if you need it (or just add it in).
Hard drive failures are really uncommon for me, though I've used Western Digital and Seagate Barracuda drives. One 12 GB Seagate Barracuda that came in a prebuilt 1996 Compaq computer was used to hell and back again, and I used it for over 10 years before it finally crapped out on me, and even then the BIOS gave me ample warning weeks before it crapped out.
If redundancy is really that much of an issue, get yourself a cheapo external USB hard drive with 'autobackup' and that way even a virus infection won't screw up your plans.
Also, I'd recommend WinXP SP3 (if you can get it from an OEM) with nLite. Much less of a resource hog than Win7. Firefox or Chrome for the web browser. Other stuff as needed.
In that case, just get an external hard drive.
