Bus Interface in gpu-z
vahid haji
Subject:Bus Interface in gpu-z
hi hi
my systm is
cpu i7 4790k
fan noctou dh-15
ram 4*8 g 32 g
vga asus rog strix 1650s oc (new shop)
ssd 240g
hhd 8 tb
power 1200 w
min biostar gaming z97x
last v bios and driver s instal
setup bios min is default
now
please see photo
https://filebin.net/archive/51xhee4cd2h8pn5d/zip?t=b9ljlfl2
install vga in slot 1
in promram gpu z ..
Bus Interface
show @x2 !!!
when install vga in slot 2
n promram gpu z ..
Bus Interface
show @x8 !!!
I CONNTACT SUPPORT BIOSRAR (MY MIN)
ANSWER
(Dear Sir,
Your graphic card specification:
Interface is x2
Asus ROG-STRIX-GTX1650S-O4G-GAMING
https://rog.asus.com/us/graphics-ca...trix/rog-strix-gtx1650s-o4g-gaming-model/spec
Further more,please check with your graphic card vendor about grapihc card specifications,thanks.)
NOW
Is this a problem with the graphics card or the motherboard?
PLEASE HELP ME FOR FIX PROBLEM
click the ? mark and start the render test, see if it goes up to x16
This. There is a power saving feature of PCI-E that will limit the amount of bandwidth fed to the card if the card doesn't need it. The render test puts a load on the video card, which will increase the bandwidth available through the slot.
That or change the power setting in power management. But it is normal to get 2.0 speeds and lower x when in powersave modes.
