Burning in new motherboard, processor, and memory?
maxamillion
What should I use to burn in a new motherboard, processor, and memory?
So far I am running prime95 in blend mode for a couple hours and everything is green. What else should I get to see if it incurs any problems?
I just run Prime 95 and Furmark for a full 24 hours to stress test the system.
just run the standard stability tests like danny said.. other then that burn-in is no longer required.. its all done by the manufacture..
No need to run furmark if its not a gaming system, btw, IMO. As sirmonkey said, you don't really need to burn-in the components. I mainly run Prime95 to test system compatibility/reliability between all the parts, not for burn-in -- if that makes any sense.
