Built my first computer post problem
david247
Hi I have just built my first computer using the following parts
corsair hx520w
msi p6n platinum
radeon x1650xt
g skill f2 6400cl4d-2gbpk
seagate barracuda 7200.9
intel pentium d processor
I am unable to get to the post process no responce from the graphics card, everything appears to be working, any ideas/suggestions of what to do next ? :confused:
Do the fans and hard drive spin up? If so try reseating your graphics card. Also are there any beeps coming from it?
Break it down to the basics....mobo, cpu/hsf, one stick of memory and your video card... If it posts, add one component at a time until you find the culprit... oh, and do this with your parts out of the case, mobo on a cardboard box.. just to make sure you don't have a short...
Good luck..
Good luck..
Thank you for your help so far
Done as above, no luck. All I get from the monitor is no input signal I have also tried another processor so does this leave me with the board or the graphic card being the problem.
What ram configuration are you using (one stick, two?) Bad ram can cause failure to post.. but a bad video card can as well... If you've tried both sticks individually and your still getting nothing I would suspect a dead mobo... but that's just me, I haven't personally seen a lot of doa video cards, it happens, I've just seen more doa mobo's... and again, I stress that this is just my guess.. that's all I can offer..
Good luck..
This is what I have done so far, I installed the graphic card and the cpu and one stick of ram to a 945 gm2 msi board and got it to work. So they are all ok, however the only difference in the boards is that the 945 gm2 has got a 12 volt power connector providing power to the pciex16 graphic card. I was wondering if this maybe the problem not enough power to the graphics card, or is the board dead ??
Regards David
I really think you have a dead board... I hope I'm wrong but I don't think I am.... Sorry..
Hate to even ask but people have forgot it before, there is an 8 pin connector near the cpu for extra 12V power, your power supply may only have a four pin, but it can be plugged in. You didnt by chance miss that ? (be sure to check the manual on how to deal with it look for Aux 12 power ).
did you try another cpu/ram/vidcard in the suspected board? you're doing all of this testing outside of a case, right?
Tried everything, tested it outside of the case,definately the board therefore am sending it back to the supplier ! Thanks to all, will let you know the outcome
