Building suggestions or approval please :D
forneus
Gaming, photoshop, design, school.
Around 500 CDN though my current build is at 661 w/ tax and shipping
3) Where do you live?
Vancouver
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU,Ram,PSU,Mobo,Gfx card
Just a lian li case from like 6 years ago, crappy cd rom drive and 2x WD Raptors 36gb for raid.
6) Will you be overclocking?
Doesn't matter
22' Benq (1920)
A big question I have is whether I should wait until after xmas to do the buying or do it now? I really wanna have the computer to play over the holidays but if prices or something are going to be that much better after the break then I can be convinced.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I want to have a little future proofing so SLI/Crossfire. Raid is needed too.
10) Do you already have a legit and reusable/transferable OS key/license?
Yeah I have Win7 64bit.
I appreciate your input and assistance if you are reading this. This will be my first build for myself in about 6 years. Back then I spent about 3,000 on a pc, Radeon 8800xt, 2gb dual chan mem, case, trimmings. I'm no longer partial to either AMD, Intel, Nvidia or ATI. But gaming will be why I'm doing this upgrade.
What I have compiled and was looking for approval on is the following (keep in mind I can be convinced to switch to run intel and ati if there is comparable pricing):
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - Retail
Item #: N82E16813128392
Return Policy: Standard Return Policy
-$10.00 Instant
$99.99
$89.99
ASUS ENGTX275/2DI/896MD3 GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Retail
Item #: N82E16814121358
$257.49
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC ... - Retail
Item #: N82E16817341017
-$31.00 Instant
$30.00 USD Mail-in Rebate
$104.99
$73.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM - Retail
Item #: N82E16820231303
Return Policy: Memory Standard Return Policy
-$21.00 Instant
$104.99
$83.99
AMD Athlon II X2 240 Regor 2.8GHz Socket AM3 65W Dual-Core Processor Model ADX240OCGQBOX - Retail
Item #: N82E16819103688
$69
This is all from newegg.ca, Thanks!
Ditch the GTX 275 as the HD 4890 performs just as well as the GTX 275 if not faster but is significantly cheaper:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150438&cm_re=HD_4890-_-14-150-438-_-Product
Ditch the OCZ PSU as it is of mediocre quality and design. I would recommend this far better Seasonic PSU:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151079
Use the savings from the video card upgrade to get a faster CPU that can keep up with the video card:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103680&Tpk=X2 550
I will do what you've suggested with the proc and card but is there a good oc'ing moboard that has xfire support or something incase I wanna upgrade in the future? I'm not sure which ones are good quality off the top of my head.
This mobo is a good overclocking motherboard with Crossfire support:
$140 CAD - Gigabyte GA-MA790GPT-UD3H AMD 790GX Motherboard
But it is $50 CAD more.
