almaster666
- Aug 18, 2009
Hey guys,
So, I currently own an OEM Acer computer (please don't tell me I should have built, I had neither the time nor the money to do so). It runs games like GTA 4 just fine for now but I need better.
So, what I have so far is this:
- AMD Athlon x2 4050e (2.1GHz) - so far, no real OC'ing possibility because of Acer Motherboard with locked BIOS.
- 4Go DDR2 RAM
- Nvidia GeForce 9500 GS - 512Mo (which I have yet to OC)
My plan is to upgrade the different components little by little (I can't afford everything at once, I'm still a student). I am first upgrading to a bigger, better ventilated case and PSU.
In a few months I'll be upgrading to a better video card (GTX 260 Core 216 or GTX 275) because my current one is bottlenecking my system more than the CPU.
And, third step, I'll upgrade my motherboard and CPU to a DDR3 and AMD Quad or Athlon x3 core processor.
My first question is:
I have bought a case, PSU and I'm getting a free heat-sink for a future CPU upgrade. What do you think of these components? Will they be sufficient for the type of setup I'm aiming for? Any suggestions?
Case: Antec Three Hundred: http://www.materiel.net/ctl/Boitiers/39143-Three_Hundred.html
Power Supply: Corsair TX 750W: http://www.materiel.net/ctl/Alimentations/33363-TX_750W.html
Heat Sink: Xigmatek HDT-S1283: http://www.materiel.net/ctl/Radiateurs_processeurs/31506-HDT_S1283.html
Thanks a lot
and sorry for the links being in French but 80% of the info is in English abbreviations anyway
EDIT: Btw, I am very patient, I don't need everything to come together at once. I understand that it's silly to run a GTX 275 on my crappy motherboard but if it's for 2 or 3 months, it's okay.
- 4Go DDR2 RAM
Thanks a lot
