Okay so I have about $2000 and I want to go with AMD so when they release the new Phenom early in 2008, I am good to go, as it uses the AM2 socket. The catch is that I need (yes, NEED
) Crysis running with maxed settings at 2560 x 1600 (Dell 30") will this system do just that?
Shipping: $23.99
Grand Total: $1,997.91
I would be using my pre-existing harddrives (unless you think thats a bad idea) and I have everything else I need, as in tower, keyboard, mouse, monitor, ect ect.
With all that said, is this a good idea to get an AMD and wait for the Phenom? Or should I just go all out right now with current processors? INFORM ME
AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 x1 ($209.99)
ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD x1 ($129.99)
EVGA 768-P2-N831-AR GeForce 8800GTX 768MB 384-bit GDDR3 PCI Express x16 x2 ($1,099.98)
CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) x1 ($259.00)
PC Power & Cooling Silencer 750 Quad (Crossfire Edition) EPS12V 750W x1 ($179.99)
Thermalright Ultra-120 Extreme CPU Cooler x1 ($64.99)
Scythe S-FLEX SFF21F 120mm Case Fan x1 ($24.99)
Arctic Silver Ceramique Thermal Compound x1 ($4.99)
Shipping: $23.99
