HolyfieldsEar
- Nov 27, 2013
Hello folks, I'm planning to upgrade my hardware for quality gaming in the coming years.
My current rig is:
Phenom II X4 970 OC'd 4.0
Gigabyte MA770T-UD3
4x2 G.Skill RAM
GTX 660 OC 2gb
2 HD total of 1TB
Antec Earthwatts 500w
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
Arctic Freezer Xtreme Rev. 2 CPU cooling
I'm trying to decide between these two builds, one AMD, one Intel, one with OC potential, the other without.
But first thing first, I'll detail my needs and budget, just in case:
>It will be used for gaming.
>My budget is $1400, maybe a few dollars more.
>I live outside the U.S., I'll be ordering parts both from Amazon.com and stores in my country(already found the best prices in my country, which are still higher than in the U.S.)
>No brand preference
>I'll be using my existing case, Antec Three Hundred(should work, no?), current HDD and DVD drive.
>Overclock is a consideration
>Resolution will most likely be 1920x1080, unless I can find a 2560x1440 monitor with input lag suitable for competitive FPS gaming, for $200-500.
>Plan to build it within a month
>Already have OS
Intel build:
Intel i5-4570
Asus B85-PLUS
Corsair Vengeance Blue 8 GB
PowerColor Radeon R9 290 OC 4GB GDDR5
Corsair VS550 550W
-$1240
AMD build:
AMD FX-8320
Asus M5A99X Evo R2.0
Noctua NH-D14
Corsair CX750 750W
-$1405
My questions are, which build is more "bang for buck"? which has better performance/price, which will serve me better as a gaming machine for today's and tomorrow's games?
Do you think a CPU with 8 cores that can be overclocked is a more future proof than a stock i5 4570?
I tried to put together an Intel build with i5 3570k/i5 4670k, but it's over my budget, so it's one or the other.
Thanks.
My current rig is:
Gigabyte MA770T-UD3
4x2 G.Skill RAM
GTX 660 OC 2gb
2 HD total of 1TB
>No brand preference
>Already have OS
Intel build:
Intel i5-4570
Asus B85-PLUS
Corsair VS550 550W
-$1240
AMD build:
AMD FX-8320
Noctua NH-D14
Corsair CX750 750W
-$1405
Thanks.
