MOSTLY Gaming and everything else you do with a PC.
2000$ U.S. Tax included, Shipping included.
Texas, Fort Worth.
Tower, Motherboard, CPU, GPU, Power Supply, RAM (12GB).
My Hard Drive will be used in my new PC as well as my optical drive, 500GB SATA II Hard Drive, and DVD RW Optical Drive. I will also reuse my Headset for a sound system, my mouse and my keyboard, including my Monitor. I might reuse my RAM 12.0 GB Dual-Channel DDR3 @ 532MHz (7-7-7-20) as well if it will fit the motherboard.
6) Will you be overclocking?
No, I will NOT be overclocking anything.
7) 7) What is the max resolution of your monitor? What size is it?
19" 1280x720
I plan to build the PC ASAP, I would like to finish it at the start of March, I want to have the PC ready for Metro: Last Light.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
I am not interested in features at the moment but I will be using the PC for gaming mostly, but opinions are welcome.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have a legit Windows 7, Home Premium on this computer now 64 bit, but will most likely use Windows 8 64bit on my new computer, opinions are welcome!
Texas, Fort Worth.
19" 1280x720
