viryoulent
- Apr 3, 2013
Gaming (Specifically: BF3, SC2, WoW) - I'm all about PvP so can't have any lag! I want the advantage
3000$ - Yes all included.
USA - 30 min from Boston - Yes there is a microcenter 30 min away and I can get the majority of parts there to save a buck.
- Motherboard
- CPU
- PSU
- Video Card(s)
- Memory
- Case
- SSD
- DVD Player/Writer/BlueRay Player/Writer? (Dont really need blueray writing but player would be nice)
- Cooling system/ or extra fans?
- OS (Windows 7 Pro OEM?)
- Monitor (pref 27" or 32" tvs are pretty cheap for like 200$- 250$) not sure the difference.
Not reusing parts, all new
6) Will you be overclocking?
I'd like too...but will have to look into it more.
7) 7) What is the max resolution of your monitor? What size is it?
Will be buying a new one but it's the standard 1960 or whatever it is x 1100 (sorry I'm a newb at this stuff)
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SLI if I decide to go dual graphics instead of a single 690 or titan?
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I will be buying the OEM Windows 7 Pro (Included with budget as listed above)
My thoughts as far as parts:
I was thinking Corsair Vengeance for memory but not sure the advantage of having a higher MHZ? Any difference as far as 1600 v 2400 that I'll honestly notice in gaming, etc? Also I was told to go RIpjaw because of same timings ?
Also I was told to save money by going the 670 FTW dual SLI nstead of 680 dual sli ? due to the fps being almost identical ?
Case I was thinking: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133202
About all I have so far
- Motherboard
- CPU
- PSU
- Video Card(s)
- Memory
- Case
- SSD
This week
