minigister
- Apr 26, 2008
MOBO: ABIT IP35 Pro - http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030
RAM: G.SKILL 4GB - [http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
CPU: Intel Core 2 Duo E8400 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
HD: Western Digital Caviar SE16 WD3200AAKS 320GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
PSU: SeaSonic S12 Energy Plus - http://www.newegg.com/Product/Product.aspx?Item=N82E16817151028
GPU: EVGA 512-P3-N841-AR GeForce 8800GTS - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130325
SC: ASUS Xonar DX - http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
OS: Windows Vista Home Premium SP1 64-bit - http://www.newegg.com/Product/Produ...488&Tpk=Windows+Vista+Home+Premium+SP1+64-bit
OD: LITE-ON - http://www.newegg.com/Product/Product.aspx?Item=N82E16827106072
Case : LIAN LI PC-A10B - http://www.newegg.com/Product/Product.aspx?Item=N82E16811112122&Tpk=PC-A10B
Monitor - haven't decided yet, I will buy probably buy dual monitors. Will be using mostly for watching movies and surfing the web.
I will probably overclock this in the future and i will use it for mild gaming. I will use this mostly for web surfing/work/music. I really have no fixed budget, I just want a good computer.
thnx for the help
thnx for the help
