Building my own computer - need advices
Ezekiel33
Hello dear hardware community :) Constructing my own PC and need advices on this great site! so here we go! :
Gaming, Photoshop, Web Design/browsing, I'll also run both Vista 64 and Xp 32
between 900$ and 1100$ all included (Canadian price)
3) Where do you live?
Montreal/Quebec/Canada (yes i'm french)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need the following :
CPU (going for Intel Quad)
RAM (going for 4 GO DDR3)
Mother Board (need help here)
Video Card (going Nvidia)
Dvd/cd Burner/reader (1 that include everything)
Hard Drive
Potentially PSU (actually using 460W 30A.. is it enough?)
Like I said, only the PSU If I can.. Tisonic Mega Power 460W 30A.. is it enough?
6) Will you be overclocking?
Not for now
7) What size monitor do you have or plan to have?
I'm actually using Samsung SyncMaster 226bw (22")
I'm officially buying my PC in May 2009 (on newegg.ca tigerdirect.ca or nxic.ca)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
At the beginning I'll only use 1 Video Card, but I want my mother board to support 2 video cards. When I can, I might simply buy a second card. I'm not using raid/firewire.
10) Do you already have a legit and reusable/transferable OS key/license?
yes I do, for both XP and Vista
I think all the information is there. I'm looking to buy on Newegg.ca Tigerdirect.ca or nxic.ca I hope nothing is missing. I want my computer to last as long as possible!! ;)
thanks for the help guys :)
Gonna let someone do the grunt work but there are a bunch of flaws present
1) LGA775 does not benefit from DDR3, period.
2) PSU most likely should be replaced, just the name is scary
3) SLI at a "later" date is a bad idea. SLI within a couple/few months is still okay, but beyond that (and if you're reaching into 6+ months) is.. stewpit.
4) List your games you intend to play.
... 7) What size monitor do you have or plan to have?
I'm actually using Samsung SyncMaster 226bw (22").. I'm not buying another screen
I guess the question should read, "and/or" instead of just "or," but what other screen do you plan on buying?
ouch, now i'm confused...
1)http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115041 that's weird, they made a combo with that CPU+ ddr3 mobo.. what other cpu do you suggest to go with ddr3 than?
2)even with only 1 video card?
3)maybe I'll just stick with 1 video card.. maybe I'll buy a second one in the next 6 months
4)latest games and the ones to come.. i just dont want to have to change my computer for a while.. and by paying the less..
Went with AMD/AM3 for a lesser money build,
Newegg Canada
1) They do make LGA775 mobos that support DDR3 RAM. However, as Lowteckh said, Core 2 Duo/Quad based systems do not benefit from DDR3 RAM. For DDR3 RAM, either AMD's new Phenom II CPUs or Intel's Core i7 CPUs are good choices.
2) Like Lowteckh, I have reservations about that PSU. Can you tell us what the number is under that U and reversed R logo? That'll tell us who the actual manufacturer is for that PSU.
Don't use anything else than a well-known good brand PSU.
That's the problem, in 6 months, there will be a cheaper video card that's two times faster than the one you'll buy now.
He said he's not buying another screen....
Yah... that post was pre-coffee this morning, lol. Why even mention you're NOT planning on buying another one? :rolleyes: :eek: :p
QFT. However, you may want to just get a Core2 w/ DDR2 board instead of Core i7/ph2 w/ DDR3.
QFMT
my mistake I'll edit my post :)
1) what about this cpu http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202 to use with ddr3 memory
2) Here is a screenshot of my PSU http://s645.photobucket.com/albums/uu179/Ezekiel33MW/?action=view&current=t2008005.jpg
3) I'll finally only buy 1 Video Card for now
Did not see you wanted an Intel build, my mistake and sorry.
1 - That definitely is a good choice in terms of the i7 cpu.
2 - Someone else will need to clarify about that psu. Not too familiar myself of that brand.
3 - Up to you man, as your build reflects your own personal choice of the compoents.
If you want, you can have 6GB for your built also. I've seen some use this particular memory kit - http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231223&Tpk=6gb gskill
no problem ;)
it's getting better now! Now I have this i7 cpu to use in conjonction with your ddr3 memory hehe. I only need to find a good mobo that will fit well with these 2 parts thanks for the help Everett! for the Video card I was thinking about this one : http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130339 looks good?
You will definately need a different power supply. It looks like its an older 5v based unit. You should look for a more quality 500-600w unit instead.
Actually, it was my mistake, just trying to play it off. :p
1) great CPU, and DDR3 is your only choice for i7 ;)
2) thats a sirtec... low quality, IIRC. you'll want to replace it.
3) you'll never need SLI for a 22" monitor. there should always be a newer gen card that will outperform two last gen cards in SLI, and you could sell the old card to help offset the cost of the new gen card.
no problem ;)
What DDR3 RAM do you currently have? model # plz.
For a 22", you may want to go with either an HD4870 or GTX260.
edit: what case will you be using?
no problem ;)
No problem and glad to help out. :)
It does look good, but it more so matters of the res you wish to use.
Anything 1680x1050 and above, I'd look more so into buying this card - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130448 price might be a bit too steep for you, but you get an awesome warranty. Support and RMA wise from that company.
As for PSU, myself would just go with 750w - http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006 | http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341011
Mobo - I'm fond of Gigabyte and would use either http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128374 or http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128362
Got to admit, when helping out people with their built I'm not exactly the best nor expert. Do feel other suggestions and tips are welcomed and don't mind if you don't take my advice. Don't worry if you find another's opinion better. :p
Oh sorry I was refering to Everett ddr3 ram link http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231223&Tpk=6gb gskill
I'm actually using a very old single core p4 2.4 with very old ram lol.. I wont even be able to sell my actual video card (agp nvidia 6800 256 mb) For the case I still dont know, I might buy it from a friend of a friend.. still have no news for that..
Ok so to resume ->
Intel Core i7 920 http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
2x2gb ddr3 ram (should i go for 1333 or 1600?)
new psu http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006
video card http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130339&Tpk=9800 GTX
not sure about the mother board yet :/ need something affordable
Hard drive http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136320
cd/dvd drive dont know yet
ouch.. this will cost too much for me I think :p have a budget around 1000$ can. This Graphic card is too expensive for me I think :( I'll check the mobo :)
