lollysticky
- Aug 23, 2008
Hi there,
I'm a bioinformatician looking to build a system to experiment and play with. It will run a Fedora 13 server 'minimal install' setup. I want a cluster of 3 nodes, and each node should be:
1) cost-effective (+ preferably low-budget) : I don't need high end CPUs
2) small: preferably mini-itx
3) no need for a graphics card... I will be running parallel programs on the cluster who do not profit from GPU power.
4) power-efficient CPU: low wattage
for each node, I was thinking along the lines of:
========== intel =========
Intel Celeron Dual Core E3300 (2 cores, 2.5Ghz, x86_64, 800Mhz FSB)
2Gig RAM
Intel Desktop Board DG41MJ
smallish SATA2 HD
Now, onto my questions:
1) does anyone in here have an idea or suggestion for another node composition? I tried to come up with a decent AMD alternative for about the same costs but I failed to do so.
2) how would I power the nodes? Three separate PSUs are over-the-top...
3) general advice
Thanks to anyone who would reply!
2Gig RAM
smallish SATA2 HD
3) general advice
