Well I'm pretty close on ordering my HTPC. This is my first HTPC, and thought I would come and let people look over it who are more versed in this field then I am.
Here is my build.
Western Digital Caviar Green WD10EACS 1TB SATA 3.0Gb/s Hard Drive - OEM
Thought about going 1.5 TB or even going smaller and just doing external drives, but ended up deciding on this drive.
GIGABYTE GA-MA78GM-S2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard - Retail
G.SKILL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory - Retail
AMD Athlon X2 4850e 2.5GHz 2 x 512KB L2 Cache Socket AM2 45W Dual-Core Processor - Retail
Figure the 4850e at 45w would be better then a 65W processor, and I figure this will be good enough to do what I need to do.
Microsoft Windows Vista Home Premium SP1 32-bit English 1pk for System Builders DSP OEI DVD - OEM
Thought about using XP pro as I already have a key, but decided it would be money better spent just going with Vista
LG Black 6X Blu-ray DVD-ROM 16X DVD-ROM 40X CD-ROM SATA Internal Combo LG Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner Model GGC-H20LK - OEM
Thought about just going regular DVD drive, but figured what the hell might as well go for the gusto and get the all in one drive now.
LTS KIT-RCST100 Vista / XP Media Center Infrared Remote Control with Receiver
Is this just a waste of money? I picked it up because it was only 22 with a combo discount.
Rosewill R379-SM Black/ Silver 0.8mm SGCC Steel MicroATX Slim Case Computer Case PSU ATX12V Flex 300W Power Supply - Retail
This case on it's side should look nice and fit in on my entertainment center nicely.
Comes to a little under 630.00 after shipping and tax.
Some notes...
I will be buying a new TV within 6 months, currently I have a 32 inch HDTV (720p I think) and will be upgrading to a 57 or 61 inch 1080p DLP HDTV. I want to make sure I future proof this thing as much as possible.
I want to be able to play any music, DVD, HD-DVD, Blu-Ray on my TV. Also any content I already have on my HTPC such as various TV shows/movies that are in 720p or hopefully up to 1080p without any stuttering or slowness, or out of sync issues.
A few things I thought about adding but decided against it for now.
TV tuner card to record shows, but decided against this right now as I feel the price of this box is about what I want to spend.
An Extra 2 gigs of ram, but would that even make any difference? or just cause more heat in the box and do more harm then good.
Thought about a different case that would be easier to add expansion cards to in the future, or even add more internal HD storage
For the future.
I would like to add external storage for even more storage, I will be using the eSATA port on the motherboard for this.
TV Tuner card - a possible addition for the future, not 100% sure I will even use one of these that much
Audio card - At some point when I upgrade my sound system I plan on adding a nice sound card to the box for better quality 7.1 sound.
Will I run into any problems with this build down the road? will I have issues watching HD content on my HD?
Anyone see any problems with this build? have any suggestions for anything? or just plain o'le comments?
edit: forgot I'll need some sort of wireless network card, will a USB card be good enough? or should I just go ahead and put an internal wireless card in the PC?
Thanks in advance for anything you guys have to say.
Here is my build.
Some notes...
For the future.
