Hey guys, i need some help. I'm in the process of building my first real storage server (well its actually going to be a combination server). Anyways i've learned a lot in the past few weeks from googling and from the anandtech forums (one guy in particular)...but unfortunately he seems awall and since i've already ordered some of the parts i'm in kind of a hurry. Anyways i will split my questions it to different threads as to not make it overbearing.
For now i will be running FreeNAS under ESXi. I currently run WHS under hyper-v which has worked fine. Maybe in the future i will want to go to ZFS under FreeNAS but probably not until FreeNAS 8 is released. I will just have a good backup strategy for redudancy. Using a combination of acronis (to replace whs backups) and crashplan to backup data on freenas
Anyways, i'm in the process of trying to pick a HBA right now. I already ordered an RPC-4220 so i need to support up to 20 drives. My motherboard (Asus P5Q Pro) has 6 SATA ports. I will use 2 of those ports for a Raid-1 of the OS partition...the remaining 4 will be used for the backplane. So i pretty much need 4 SFF-8087 ports. Being highly compatible (100% ESXi is required). A guy over at anandtech almost immediately recommended the LSI 1068E based card. Now it seems like there is no perfect options out there. These cards seem to sometimes have problems with power manangement and SMART functionatity. That being said there are a couple options here.
I looked at the supermicro cards but they seem to only be UIO which means they wouldn't be compatible with my case
. There also is this card:
http://www.scsi4me.com/ibm-serveraid-br10i-8-port-pci-express-sas-raid-controller.html
The price is tempting. I emailed them and they told me it is compatible with an ATX case but i don't know. I have a hard time believing it. Low profile md2 adaptor?
Then there is the Intel SASUC8I. Its ATX but its priced about $40 more per card. Should i just don't bother with the headache and get the intel card?
I see a lot of people flashing the intel card to the LSI firmware? Why? I looked on LSI site & intel site and actually intels firmware revision was newer. What advatanges does it offer?
So guys what should i do here? Or should i not go with a 1068e based card? I also looked at a LSI 2008 based card but i don't see any ESXi support.
thanks for your help,
Ncage
Ncage
