PrometheuSBoxeR
- Sep 21, 2005
This HTPC will be hooked up to my big screen, and eventually a stereo system (will be buying in a later date when I have more money). I plan to watch streams of all kinds, listen to my music collection/online music, rip blu-rays onto HDD and play them back at a later date, watch every form of 1080p media there is, surf the web/email from my couch. The PC will be on quite a few hours each day, if not 24/7. I might keep it on during the day as a torrent/download box while I am at work.
I'm always open minded and have a bang for budget mindset. I don't have a set price, but I would like it to be as cheap as possible as long as it can accomplish my goals.
3) Where do you live?
Delaware
4) What exact parts do you need for that budget?
Everything for the "tower" - case, mobo, psu, cpu, gpu, mem, HDD, blu-ray etc. No prepherials, just the tower and all the parts to it.
5)If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model.
N/A
6) Will you be overclocking?
Likely not, but a mild overclock if it is easily feasible/a possibility, is it recommended is the real question? Consider power usage/power bill/amount of on-time, and heat/space.
Already mentioned, will be on my big screen.
Shortly.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I plan on having 2-3 2TB HDD's in the HTPC. I don't have a need for much more than that. I only need the minimum requirements to meet my goals, and keep costs down.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, I use Windows 7 Ultimate 64-bit
Thank you for your time, energy, and help.
Sincerely,
PrometheuSBoxeR
Delaware
N/A
Shortly.
Sincerely,
PrometheuSBoxeR
