Building gaming computer on $750 budget?
darkhunter139
Ok well my cousion wants to build his first computer and I am going to help him. I have built two already about 6 months ago but I know how much can change in that time. Basically he wants the best gaming comp he can get on a $750 budget. What is the current good value CPU's and GPUs that are reccomended right now? Once I decide on those two ill start trying to put a whole build together and see what you guys think.
EDIT: He doesnt need a monitor either
Thanks in advance
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
Yes
750 can probably go up to 800 with tax and shipping included yes
3) Where do you live?
PA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything but a monitor
None
6) Will you be overclocking?
No
19 inch flat panel dell montior, possible upgrade in the future
Building
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Not to picky about this
10) Do you already have a legit and reusable/transferable OS key/license?
No will be getting vista
AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Black Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103649&Tpk=AMD Phenom II X3 720 $147
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128376&Tpk=GIGABYTE GA-MA770-UD3 $75
XIGMATEK Red Scorpion HDT-RS1283 120mm CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233012&Tpk=HDT-RS1283 $33
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail $5 off w/ promo code EMCLNNP29, while supplies last
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122 $44
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319 $80
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136153 $25
BFG Tech LS-450 450W ATX12V V2.2 80 PLUS Certified Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702014&Tpk=BFG 450 $60
GIGABYTE GV-N250ZL-1GI GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125266 $150
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=antec 300 $60
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488 $100
Total before S&H $714
lt shiro's build looks good. ;) If shipping is too high, find a different etailer for the case (buy.com, provantage.com, directron.com, etc).
lt shiro's build is good but I'd make the following change:
Go with this Corsair PSU since it has 1A more than the LS-450 and comes with free shipping (Oh and the BFG link is the same as the Gigabyte card link):
Corsair 400CX 400W PSU - $60
AMD cards actually stack up agaisnt intel now?
Yes AMD CPUs now stack up pretty well compared to similarly priced Intel CPUs. However the performance crown still belongs to Intel with their Core i7 CPUs.
I see. Thanks for the input I will throw something together and post it to see what you guys think.
Those are also a good set. They also have a promocode for that set in the [H]ardDeals forum:
http://www.hardforum.com/showthread.php?t=1400893
Also, I'd probably recommend a HD4870 1GB over the GTS250. The performance is worth it:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
I also hear they might be reaching $179 soon.
Edit: I may have spoken too soon, there is a good deal on a GTX260 over at newegg as well:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130434
Though, I wouldn't recommend that BFG 450 with the 4870 the 550W is 20 dollars more.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702008
With rebates, you should be able to make it around $750.
Edit Part deux:
Make sure to look for package deals. This package includes an OC'd 260 and the Phenom for 10 dollars less than the individual non OC'd 260 and the Phenom:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.173510
Also a good package with the Antec 300 case and a 500W Earthwatts:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.165599
Heres a good one
DVD: Samsung - $19 (in cart...)
CASE: Antec 300 - $60
HD: Western Digital 640GB - $70
GPU: Saphire 4850 512MB - $145 + $10 MIR
PSU: CORSAIR 400Watt - $60 + $10 MIR
RAM: G.SKILL 4GB (2 x 2GB) DDR2 800 - $45
MOBO: GIGABYTE GA-G31M-ES2L LGA 775 Intel G31 Micro ATX - $53
CPU: Intel 8400 3.0Ghz - $165
Subtotal: $621.88
Tax: $45.09 (95822)
Shipping: $26.22
Grand Total: $693.19 (w/ tax)
Grand Total: $652.10 (w/o tax)
the corsair psu is out of stock but with the extra money id say get a 500ish watt one and a 4870 instead of the 4850.
Otherwise the above is a sweet build for how cheap it is (yes the mobo is micro atx)
It-Shiro build is good but since your not OC'ing or anything I would drop the 3rd party CPU cooler just use the standard cooler that comes with processor.
also go with a amd HD4870 over the gtx 250.
imo
I think im gonna go with this build exceptfor this hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
Does taht look good
Does taht look good
lt_shiro's HDD choice, the 640GB, is much faster than the 500GB, unless that 500GB model is a single platter drive. The 640GB uses 320GB platters, making it faster than the 250GB platters I'm assuming the 500GB uses. Though, I heard they now have 500GB platters, so I'm unsure if the black model uses those or not. If and when you (or anyone else) find out, let us know.
imo
Two reason for using the Xigmatech, its so much more quiet than the stock and 720/7750 BE sometimes don't have heatsink with the CPU.
It isnt available anymore is there something besides the one I posted for a similar price?
The Blue version is a good alternative, if you want to get everything from the egg (WD6400AAKS). However, for the extra $5, you get 2 more years of warranty. Performance between the two drives is nearly identical.
CPU i7 920
Asus P6T DE
GF295 SLI
Ocz 12 /1600 Triple Channel DDR3
Seagate 1TB
ThermalTake ToughPower 1200
SB X-Fi Titanium Fatal1ty Champion Serie
Coolermaster Cosmos 1000
Logitech MX5500 Combo
Vista Ultimate 64bit
