Building first PC
zanzanegi
the middle ground of gaming(playing LoL a lot lately might pick up an FPS in the future) and web browsing.
Don't want to spend above $700 including tax+ship
Rochester, New York USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
CPU, Mobo, RAM, Case, keyboard, fans if recommended, graphics card, power supply. I think that's all if I am missing anything please let me know.
Don't have any leftovers
6) Will you be overclocking?
Most likely not.
I have a LG flatron 22in 1080p
In a couple of weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Don't think I'll need any of these. Unless its really recommended.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Nope
I am really new to computers so I hope I have provided enough information for a build. Please take care of me!! :D
I'm in a slightly lazy mood so I'll post info on how I put a machine together. First, I touch the metal part of the case for 30 seconds to get rid of static electricity. (I also wear a wrist strap or whatever you call it but that's my choice.) Then I install the CPU and RAM on the mobo. Depending on the type of heatsink I have, I may install the heatsink as well. Then I install the power supply in the case. Then the in and out shield in the case. Then I install the motherboard with CPU, RAM (and maybe heatsink). Then I slide in and install the HD and DVD-RW. When I first boot, I change the boot order in the BIOS to start with the optical drive then the hard drive and check the speed of the CPU and RAM. I also adjust the time/date. (I also prefer to flash the BIOS to current one.)
$180 - Intel Core i5-2300 CPU
$80 - Biostar TH67B Intel H67 mAT Motherboard
$40 - G.Skill Value Series F3-10666CL9D-4GBNT 4GB DDR3 1333 RAM
$118 - XFX HD-677X-ZNLC Radeon HD 6770 1GB PCI-E Video Card
$156 - Hitachi Desktar 7K1000.D HDS721010DLE630 1TB SATA 6.0Gb/s Hard Drive
$18 - Samsung SH-222AL/BSBE SATA DVD Burner
$58 - Antec NEO ECO 520C 520W PSU
$53 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Total: $703 shipped
Ah sorry I should have read thoroughly ><
one last question, I have Logitech 5.1 X-530 Speakers. Would i also need a sound card for the surround sound to work?
The H67 posted above supports all the way up to 7.1 AFAIK.
May not give as good a sound quality as expensive sound cards but I think it will do.
